跳转到主内容
Poin2 Chromebook 11 Battery Replacement
你所需要的
  1. Poin2 Chromebook 11 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Poin2 Chromebook 11 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Battery Replacement: 步骤 2 中的图像 1,3 Poin2 Chromebook 11 Battery Replacement: 步骤 2 中的图像 2,3 Poin2 Chromebook 11 Battery Replacement: 步骤 2 中的图像 3,3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Battery Replacement: 步骤 3 中的图像 1,3 Poin2 Chromebook 11 Battery Replacement: 步骤 3 中的图像 2,3 Poin2 Chromebook 11 Battery Replacement: 步骤 3 中的图像 3,3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Battery Replacement: 步骤 4 中的图像 1,2 Poin2 Chromebook 11 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Battery Replacement: 步骤 5 中的图像 1,1
    • Lift the battery from the frame.
结论
To reassemble your Poin2 Chromebook 11, follow these instructions in reverse order.
2等其他人完成本指南。
一条评论
An important piece of information missing is the battery replacement number.
a Google search brings up no references.
Marty Sharik - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 888
