1. The picture shows the items. In the handpiece are the motor housing with the top right anchor. Underneath, on the right, is the clamping body for the tools and to the left thereof the receptacle of the clamping body. The engine is to take after replacement of the ball bearings about 350mA at 24 volts.
    • The picture shows the items. In the handpiece are the motor housing with the top right anchor. Underneath, on the right, is the clamping body for the tools and to the left thereof the receptacle of the clamping body. The engine is to take after replacement of the ball bearings about 350mA at 24 volts.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. To prevent water from entering the drive, I cut silicone gaskets out of an old cable and put them on the tubes. Now, no water can penetrate the camps. To prevent water from entering the drive, I cut silicone gaskets out of an old cable and put them on the tubes. Now, no water can penetrate the camps.
    • To prevent water from entering the drive, I cut silicone gaskets out of an old cable and put them on the tubes. Now, no water can penetrate the camps.
结论
Repeat the steps in order to reassemble your device.
特别感谢这些译者︰
100%
irlanda正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Michael
于2016年01月08日注册
10 信誉积分
撰写一个指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 200
