跳转到主内容
Pocket Knife Wooden Casing Replacement
你所需要的
  1. Pocket Knife Wooden Casing Replacement, Wooden Casing: 步骤 1 中的图像 1,2 Pocket Knife Wooden Casing Replacement, Wooden Casing: 步骤 1 中的图像 2,2
    • Trace the knife outline onto wood.
  2. Pocket Knife Wooden Casing Replacement: 步骤 2 中的图像 1,2 Pocket Knife Wooden Casing Replacement: 步骤 2 中的图像 2,2
    • Cut out the outline of the wood.
    • Cut the height of the wood to the correct measurement.
  3. Pocket Knife Wooden Casing Replacement: 步骤 3 中的图像 1,2 Pocket Knife Wooden Casing Replacement: 步骤 3 中的图像 2,2
    • Sand the wood so that it is smooth and free of hard edges.
    • For the best result, sand in the direction of the grain as much as possible.
  4. Pocket Knife Wooden Casing Replacement: 步骤 4 中的图像 1,3 Pocket Knife Wooden Casing Replacement: 步骤 4 中的图像 2,3 Pocket Knife Wooden Casing Replacement: 步骤 4 中的图像 3,3
    • Stain and polish the wood so that it is reflects the other side of the knife.
    • Apply another coat after the first coat dries if you want a darker stain.
    • If you get the Stain and Polish on your skin, your skin might be stained for a few days. In this case, make sure you wash thoroughly; Stain and Polish is only toxic if it is ingested.
  5. Pocket Knife Wooden Casing Replacement: 步骤 5 中的图像 1,2 Pocket Knife Wooden Casing Replacement: 步骤 5 中的图像 2,2
    • Drill four small holes that will go over the extruded parts of the knife.
    • You can accurately mark the positions of the holes by coloring the screw heads with sharpie then stamping them into the wood.
  6. Pocket Knife Wooden Casing Replacement: 步骤 6 中的图像 1,3 Pocket Knife Wooden Casing Replacement: 步骤 6 中的图像 2,3 Pocket Knife Wooden Casing Replacement: 步骤 6 中的图像 3,3
    • Glue the wood to the knife and clean any hard edges or excess glue that comes from this step.
终点
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 13
总计 394
