跳转到主内容
Pneumatic Door Closer Replacement
你所需要的
  1. Pneumatic Door Closer Replacement, Pneumatic Door Closer: 步骤 1 中的图像 1,2 Pneumatic Door Closer Replacement, Pneumatic Door Closer: 步骤 1 中的图像 2,2
    • Identify the broken part of the door.
  2. Pneumatic Door Closer Replacement: 步骤 2 中的图像 1,2 Pneumatic Door Closer Replacement: 步骤 2 中的图像 2,2
    • Remove the screws from the inner brackets that connect to the door closer using a screwdriver.
  3. Pneumatic Door Closer Replacement: 步骤 3 中的图像 1,3 Pneumatic Door Closer Replacement: 步骤 3 中的图像 2,3 Pneumatic Door Closer Replacement: 步骤 3 中的图像 3,3
    • Remove the screws from the outer bracket that connect to the door closer using a screwdriver.
  4. Pneumatic Door Closer Replacement: 步骤 4 中的图像 1,2 Pneumatic Door Closer Replacement: 步骤 4 中的图像 2,2
    • Install the inner bracket that attaches to the door closer by screwing the inner part into the wall using a screwdriver.
  5. Pneumatic Door Closer Replacement: 步骤 5 中的图像 1,3 Pneumatic Door Closer Replacement: 步骤 5 中的图像 2,3 Pneumatic Door Closer Replacement: 步骤 5 中的图像 3,3
    • Plug the smallest included screw into the inner bracket to attach the door closer.
  6. Pneumatic Door Closer Replacement: 步骤 6 中的图像 1,3 Pneumatic Door Closer Replacement: 步骤 6 中的图像 2,3 Pneumatic Door Closer Replacement: 步骤 6 中的图像 3,3
    • Close the door.
    • Install the outer bracket that attaches to the door closer by screwing it into the door using a screwdriver.
  7. Pneumatic Door Closer Replacement: 步骤 7 中的图像 1,3 Pneumatic Door Closer Replacement: 步骤 7 中的图像 2,3 Pneumatic Door Closer Replacement: 步骤 7 中的图像 3,3
    • Attach the door closer into the installed outer bracket by plugging the larger included screw into the inner part.
  8. Pneumatic Door Closer Replacement: 步骤 8 中的图像 1,2 Pneumatic Door Closer Replacement: 步骤 8 中的图像 2,2
    • Make sure the door closes and opens properly.
    • Adjust the hydraulics by loosening or tightening the screw on the top of the hydraulic axle to have optimal performance.
终点
Abdullah Kaddura
于02/24/21注册
157 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 639
