跳转到主内容
Plum Optimax 10 Motherboard Replacement
你所需要的
  1. Plum Optimax 10 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Plum Optimax 10 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Motherboard Replacement: 步骤 2 中的图像 1,2 Plum Optimax 10 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,2 Plum Optimax 10 Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Use flathead screwdriver tool to remove the three 2.5 mm screws shown in the photo. Two screws are located at the base of the motherboard and there is one screw located at the top.
  4. Plum Optimax 10 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Once screws are removed, carefully remove the motherboard out of encasing.
结论
另外一个人完成了本指南。
Samantha Wright
于11/06/18注册
243 声望
创作了2篇指南
团队
IUPUI, Team S1-G4, Hovde Fall 2018 IUPUI, Team S1-G4, Hovde Fall 2018 的会员
IUPUI-HOVDE-F18S1G4
3 名成员
创作了6篇指南
一条评论
This document is incomplete. It does not detail removing the cables connected to the motherboard.
Before the motherboard can be removed from the case, the Digitizer, the LCD and the power and camera cables must also be removed. the speakers, vibrator and Mic can come out with the motherboard.
George Earl Martin - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 8
总计 166
