跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
The function of a XLR cable is to carry a balanced audio signal. It connects in the bottom of the microphone to the XLR microphone connector.
  1. Make sure you have a proper three pin XLR cable.
    • Make sure you have a proper three pin XLR cable.
    • Grab the female end of the cable (plug with three holes).
  2. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  3. Line up the pins in the end of the microphone (microphone connecter) with the holes in the XLR cable.
    • Line up the pins in the end of the microphone (microphone connecter) with the holes in the XLR cable.
  4. Once the pins are aligned, push the cable into the bottom end of the microphone. You should hear a click.
    • Once the pins are aligned, push the cable into the bottom end of the microphone. You should hear a click.
结论
To disconnect the cable from the microphone, follow the instructions in reverse.
13等其他人完成本指南。
nat coll
于2012年09月27日注册
508 信誉积分
创作了14篇指南
团队
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G53
5 名成员
创作了18篇指南
When disconnecting the cable - press the little latch (pointing towards you in the last picture) to release and then pull the cable out.
harrywwc - 回复
Is this April's fool? XD
s6963172 - 回复
how i repair the PG48 the XLR conector moves in and out when the cable ar plugged. The conector male in the microphone have an screw but that one not works...
What am i do?
If you have an idea to the answer or any tip to resolve this trouble feel fre to tweet me.
@ Theradioholic
on
#Twitter
Santiago Morales - 回复
I know a few people who would see this and still screw it up.
jimboc - 回复
do it in reverse? you have to press the button though on the male end...
Michael Fox - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 9
过去的30天: 58
总计 60,634
