跳转到主内容
Playstation Classic Power Button Replacement
你所需要的
  1. Playstation Classic Power Button Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Flip the console so its back is facing up.
  2. Playstation Classic Power Button Replacement: 步骤 2 中的图像 1,1
    • Remove the five 8mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. Playstation Classic Power Button Replacement: 步骤 3 中的图像 1,3 Playstation Classic Power Button Replacement: 步骤 3 中的图像 2,3 Playstation Classic Power Button Replacement: 步骤 3 中的图像 3,3
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. Playstation Classic Power Button Replacement: 步骤 4 中的图像 1,1
    • Unscrew the motherboard's four 6mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. Playstation Classic Power Button Replacement: 步骤 5 中的图像 1,3 Playstation Classic Power Button Replacement: 步骤 5 中的图像 2,3 Playstation Classic Power Button Replacement: 步骤 5 中的图像 3,3
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. Playstation Classic Power Button Replacement: 步骤 6 中的图像 1,3 Playstation Classic Power Button Replacement: 步骤 6 中的图像 2,3 Playstation Classic Power Button Replacement: 步骤 6 中的图像 3,3
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
  7. Playstation Classic Power Button Replacement, Power Button: 步骤 7 中的图像 1,3 Playstation Classic Power Button Replacement, Power Button: 步骤 7 中的图像 2,3 Playstation Classic Power Button Replacement, Power Button: 步骤 7 中的图像 3,3
    • After removing the motherboard, position the casing so that the back of the power button is visible.
    • Use a spudger to apply pressure inward on the three plastic clips.
    • This will loosen the button enough to remove it from its position.
  8. Playstation Classic Power Button Replacement: 步骤 8 中的图像 1,3 Playstation Classic Power Button Replacement: 步骤 8 中的图像 2,3 Playstation Classic Power Button Replacement: 步骤 8 中的图像 3,3
    • Flip the casing to its front and remove the loose button with your hand.
    • Leave the spring in its original position.
结论
To reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Maxwell Webb
于04/22/19注册
703 声望
创作了5篇指南
团队
Cal Poly, Team S2-G8, Maness Spring 2019 Cal Poly, Team S2-G8, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G8
2 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 53
总计 3,295
