跳转到主内容
Playstation Classic Motherboard Replacement
你所需要的
  1. Playstation Classic Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Flip the console so its back is facing up.
  2. Playstation Classic Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the five 8mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. Playstation Classic Motherboard Replacement: 步骤 3 中的图像 1,3 Playstation Classic Motherboard Replacement: 步骤 3 中的图像 2,3 Playstation Classic Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. Playstation Classic Motherboard Replacement: 步骤 4 中的图像 1,1
    • Unscrew the motherboard's four 6mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. Playstation Classic Motherboard Replacement: 步骤 5 中的图像 1,3 Playstation Classic Motherboard Replacement: 步骤 5 中的图像 2,3 Playstation Classic Motherboard Replacement: 步骤 5 中的图像 3,3
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. Playstation Classic Motherboard Replacement: 步骤 6 中的图像 1,3 Playstation Classic Motherboard Replacement: 步骤 6 中的图像 2,3 Playstation Classic Motherboard Replacement: 步骤 6 中的图像 3,3
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
结论
6等其他人完成本指南。
Maxwell Webb
于04/22/19注册
703 声望
创作了5篇指南
团队
Cal Poly, Team S2-G8, Maness Spring 2019 Cal Poly, Team S2-G8, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G8
2 名成员
创作了24篇指南
2指南评论
where do you get a ps1 classic mini motherboard ?
blaqdemon69 - 回复
You would probably be cannibalizing a broken PS1 Classic for its motherboard. Perhaps "Parts Only."
Matt Latsha -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 24
过去 30 天: 86
总计 5,076
