跳转到主内容
Playstation Classic Controller Cord Replacement
你所需要的
  1. Playstation Classic Controller Cord Replacement, Controller Cord: 步骤 1 中的图像 1,3 Playstation Classic Controller Cord Replacement, Controller Cord: 步骤 1 中的图像 2,3 Playstation Classic Controller Cord Replacement, Controller Cord: 步骤 1 中的图像 3,3
    • Turn the controller over so that the screws are facing up.
  2. Playstation Classic Controller Cord Replacement: 步骤 2 中的图像 1,1
    • Use a small Phillips #0 screwdriver to remove the eight Xmm screws.
    • Make sure to store the screws in a safe place so they are not lost before reassembly.
  3. Playstation Classic Controller Cord Replacement: 步骤 3 中的图像 1,3 Playstation Classic Controller Cord Replacement: 步骤 3 中的图像 2,3 Playstation Classic Controller Cord Replacement: 步骤 3 中的图像 3,3
    • Use the Jimmy tool to take the back part off and get into the controller.
    • It shouldn’t take too much force to remove the back part. Make sure all screws are taken out beforehand so you avoid hurting yourself or damaging the controller.
  4. Playstation Classic Controller Cord Replacement: 步骤 4 中的图像 1,1
    • You will notice that the controller cord is plugged into a Micro USB port on the controller motherboard.
  5. Playstation Classic Controller Cord Replacement: 步骤 5 中的图像 1,3 Playstation Classic Controller Cord Replacement: 步骤 5 中的图像 2,3 Playstation Classic Controller Cord Replacement: 步骤 5 中的图像 3,3
    • To unplug the cord from the controller motherboard, carefully take the cord out from in between the small pegs that it is nestled into.
    • When unplugging the cord, hold the controller so that no significant pressure is being applied to the motherboard that will damage it.
结论
3等其他人完成本指南。
Maxwell Webb
于04/22/19注册
631 声望
创作了5篇指南
团队
Cal Poly, Team S2-G8, Maness Spring 2019 Cal Poly, Team S2-G8, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G8
2 名成员
创作了22篇指南
2条评论
Will this fix the controller being unresponsive?
Jamal Saeed - 回复
maybe but It depends
enrique bengaura -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 74
总计 6,150
