跳转到主内容
加入维修社区 - 创建账户
Playstation 3 Fan Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Playstation 3 Fan Replacement, Top Cover: 步骤 1 中的图像 1,2 Playstation 3 Fan Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Fan Replacement: 步骤 3 中的图像 1,2 Playstation 3 Fan Replacement: 步骤 3 中的图像 2,2
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Fan Replacement: 步骤 4 中的图像 1,2 Playstation 3 Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Fan Replacement: 步骤 5 中的图像 1,3 Playstation 3 Fan Replacement: 步骤 5 中的图像 2,3 Playstation 3 Fan Replacement: 步骤 5 中的图像 3,3
    • You can now lift off the top cover.
  6. Playstation 3 Fan Replacement, Power Supply: 步骤 6 中的图像 1,2 Playstation 3 Fan Replacement, Power Supply: 步骤 6 中的图像 2,2
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Playstation 3 Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Playstation 3 Fan Replacement: 步骤 8 中的图像 1,2 Playstation 3 Fan Replacement: 步骤 8 中的图像 2,2
    • Remove the power supply by lifting it straight up.
  9. Playstation 3 Fan Replacement, Motherboard Enclosure: 步骤 9 中的图像 1,2 Playstation 3 Fan Replacement, Motherboard Enclosure: 步骤 9 中的图像 2,2
    • Unplug the optical drive power cable.
    • Detach the ribbon cable that connects the optical drive to the motherboard.
    • Set the optical drive aside.
  10. Playstation 3 Fan Replacement: 步骤 10 中的图像 1,2 Playstation 3 Fan Replacement: 步骤 10 中的图像 2,2
    • Remove three screws (Phillips #2) from the wireless board and antenna.
    • Detach the ribbon cable that connects the wireless board to the motherboard.
  11. Playstation 3 Fan Replacement: 步骤 11 中的图像 1,1
    • Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
  12. Playstation 3 Fan Replacement: 步骤 12 中的图像 1,3 Playstation 3 Fan Replacement: 步骤 12 中的图像 2,3 Playstation 3 Fan Replacement: 步骤 12 中的图像 3,3
    • Remove the hard drive door with a spudger.
    • Lift the metal enclosure out of the plastic bottom case.
  13. Playstation 3 Fan Replacement, Fan: 步骤 13 中的图像 1,1
    • Remove the three screws (Phillips #2).
    • Disconnect the fan's power cable.
    • Lift the fan straight up and out.
结论
另外一个人完成了本指南。
iDeleted
于07/07/10注册
2,101 声望
创作了39篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 2,849
