简介
This guide takes you through the process of installing the Wi-Fi antenna on the PlayStation Vita. This is the white antenna cable on the right side of the wireless card.
你所需要的
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Using the pointy end of a spudger, gently pry the white Wi-Fi antenna cable connecotr off of the wireless card.
Deroute the Wi-Fi antenna cable out of the black plastic casing.
4条评论
Is WiFi / 3G antenna cable: UFL/IPEX to UFL/IPEX 1.3mm? What is the white cable length?
Yeah this is not a Wifi antenna cable. The "wireless card" only does 3G and GPS/Glonass. Wifi controller is on the mainboard itself.
