简介
This guide takes you through the process of installing the start/select button on the PlayStation Vita.
你所需要的
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
Pry up the right shoulder button casing with a spudger and set it aside.
Using the pointy end of a spudger, detach the antenna cable on the right button board.
Remove the antenna cable.
3等其他人完成本指南。
