跳转到主内容
PlayStation Vita Speakers Replacement
你所需要的
  1. PlayStation Vita Speakers Replacement, Case Separation: 步骤 1 中的图像 1,2 PlayStation Vita Speakers Replacement, Case Separation: 步骤 1 中的图像 2,2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Speakers Replacement: 步骤 2 中的图像 1,3 PlayStation Vita Speakers Replacement: 步骤 2 中的图像 2,3 PlayStation Vita Speakers Replacement: 步骤 2 中的图像 3,3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Speakers Replacement: 步骤 3 中的图像 1,2 PlayStation Vita Speakers Replacement: 步骤 3 中的图像 2,2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Speakers Replacement: 步骤 4 中的图像 1,3 PlayStation Vita Speakers Replacement: 步骤 4 中的图像 2,3 PlayStation Vita Speakers Replacement: 步骤 4 中的图像 3,3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Speakers Replacement: 步骤 5 中的图像 1,2 PlayStation Vita Speakers Replacement: 步骤 5 中的图像 2,2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Speakers Replacement: 步骤 6 中的图像 1,1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Speakers Replacement: 步骤 7 中的图像 1,1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Speakers Replacement: 步骤 8 中的图像 1,1
    • Separate the front and rear cases.
  9. PlayStation Vita Speakers Replacement, Speakers: 步骤 9 中的图像 1,2 PlayStation Vita Speakers Replacement, Speakers: 步骤 9 中的图像 2,2
    • Gently insert a spudger along the side of the speaker on the back casing assembly. Pry the speaker off the casing and remove it.
    • The speaker is adhered to the casing with light tape, which may give the speaker light resistance.
结论
3等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
89,128 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,074篇指南
2条评论
My Ps vita is still not playing sound with the volume all the way up. Think this could be electrical?
Sarah - 回复
my ps vita 3G model get washed, i dismantle the console and both speakers to let it dry. 1 month later my vita woke up but now the speakers sound bad, is there a way to fix them?
Luis Hernández - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 36
过去 30 天: 132
总计 12,581
