跳转到主内容
PlayStation Vita SIM Card Reader Replacement
你所需要的
  1. PlayStation Vita SIM Card Reader Replacement, Case Separation: 步骤 1 中的图像 1,2 PlayStation Vita SIM Card Reader Replacement, Case Separation: 步骤 1 中的图像 2,2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita SIM Card Reader Replacement: 步骤 2 中的图像 1,3 PlayStation Vita SIM Card Reader Replacement: 步骤 2 中的图像 2,3 PlayStation Vita SIM Card Reader Replacement: 步骤 2 中的图像 3,3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita SIM Card Reader Replacement: 步骤 3 中的图像 1,2 PlayStation Vita SIM Card Reader Replacement: 步骤 3 中的图像 2,2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita SIM Card Reader Replacement: 步骤 4 中的图像 1,3 PlayStation Vita SIM Card Reader Replacement: 步骤 4 中的图像 2,3 PlayStation Vita SIM Card Reader Replacement: 步骤 4 中的图像 3,3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita SIM Card Reader Replacement: 步骤 5 中的图像 1,2 PlayStation Vita SIM Card Reader Replacement: 步骤 5 中的图像 2,2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita SIM Card Reader Replacement: 步骤 6 中的图像 1,1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita SIM Card Reader Replacement: 步骤 7 中的图像 1,1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita SIM Card Reader Replacement: 步骤 8 中的图像 1,1
    • Separate the front and rear cases.
  9. PlayStation Vita SIM Card Reader Replacement, SIM Card Reader: 步骤 9 中的图像 1,2 PlayStation Vita SIM Card Reader Replacement, SIM Card Reader: 步骤 9 中的图像 2,2
    • Gently pry open the tab of the flex cable socket on top of the SIM card reader.
    • Free the flex cable by sliding the spudger underneath it and pulling it out of the socket. Rest the flex cable out of the way.
  10. PlayStation Vita SIM Card Reader Replacement: 步骤 10 中的图像 1,3 PlayStation Vita SIM Card Reader Replacement: 步骤 10 中的图像 2,3 PlayStation Vita SIM Card Reader Replacement: 步骤 10 中的图像 3,3
    • Use a spudger to release the plastic tab along the inside of the case and gently pry up the SIM card reader.
  11. PlayStation Vita SIM Card Reader Replacement: 步骤 11 中的图像 1,3 PlayStation Vita SIM Card Reader Replacement: 步骤 11 中的图像 2,3 PlayStation Vita SIM Card Reader Replacement: 步骤 11 中的图像 3,3
    • Lift the SIM card reader out of the casing.
    • Using a Phillips #00 screwdriver, remove the blue, 5.0mm screw from the SIM car reader.
    • Separate the SIM card reader from the SIM card reader retainer.
结论
另外一个人完成了本指南。
Brittany McCrigler
于03/05/12注册
89,128 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,074篇指南
一条评论
I have an error relating to the reader on my Vita. If I took it out without replacing it, will it cause the same or different error so I have to replace it, or will it be (somewhat) fine??
christoffersen366 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 28
总计 9,279
