简介
This guide takes you through installing the SIM card reader on the PlayStation Vita.
你所需要的
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Gently pry open the tab of the flex cable socket on top of the SIM card reader.
Free the flex cable by sliding the spudger underneath it and pulling it out of the socket. Rest the flex cable out of the way.
另外一个人完成了本指南。
一条评论
I have an error relating to the reader on my Vita. If I took it out without replacing it, will it cause the same or different error so I have to replace it, or will it be (somewhat) fine??
