跳转到主内容
PlayStation Vita Right Button Board Replacement
你所需要的
  1. PlayStation Vita Right Button Board Replacement, Case Separation: 步骤 1 中的图像 1,2 PlayStation Vita Right Button Board Replacement, Case Separation: 步骤 1 中的图像 2,2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Right Button Board Replacement: 步骤 2 中的图像 1,3 PlayStation Vita Right Button Board Replacement: 步骤 2 中的图像 2,3 PlayStation Vita Right Button Board Replacement: 步骤 2 中的图像 3,3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Right Button Board Replacement: 步骤 3 中的图像 1,2 PlayStation Vita Right Button Board Replacement: 步骤 3 中的图像 2,2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Right Button Board Replacement: 步骤 4 中的图像 1,3 PlayStation Vita Right Button Board Replacement: 步骤 4 中的图像 2,3 PlayStation Vita Right Button Board Replacement: 步骤 4 中的图像 3,3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Right Button Board Replacement: 步骤 5 中的图像 1,2 PlayStation Vita Right Button Board Replacement: 步骤 5 中的图像 2,2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Right Button Board Replacement: 步骤 6 中的图像 1,1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Right Button Board Replacement: 步骤 7 中的图像 1,1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Right Button Board Replacement: 步骤 8 中的图像 1,1
    • Separate the front and rear cases.
  9. PlayStation Vita Right Button Board Replacement, Wireless Card: 步骤 9 中的图像 1,3 PlayStation Vita Right Button Board Replacement, Wireless Card: 步骤 9 中的图像 2,3 PlayStation Vita Right Button Board Replacement, Wireless Card: 步骤 9 中的图像 3,3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Right Button Board Replacement: 步骤 10 中的图像 1,2 PlayStation Vita Right Button Board Replacement: 步骤 10 中的图像 2,2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Right Button Board Replacement: 步骤 11 中的图像 1,2 PlayStation Vita Right Button Board Replacement: 步骤 11 中的图像 2,2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Right Button Board Replacement, Right Shoulder Button: 步骤 12 中的图像 1,3 PlayStation Vita Right Button Board Replacement, Right Shoulder Button: 步骤 12 中的图像 2,3 PlayStation Vita Right Button Board Replacement, Right Shoulder Button: 步骤 12 中的图像 3,3
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Right Button Board Replacement: 步骤 13 中的图像 1,1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Right Button Board Replacement: 步骤 14 中的图像 1,3 PlayStation Vita Right Button Board Replacement: 步骤 14 中的图像 2,3 PlayStation Vita Right Button Board Replacement: 步骤 14 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Right Button Board Replacement: 步骤 15 中的图像 1,2 PlayStation Vita Right Button Board Replacement: 步骤 15 中的图像 2,2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Right Button Board Replacement, Right Button Board: 步骤 16 中的图像 1,2 PlayStation Vita Right Button Board Replacement, Right Button Board: 步骤 16 中的图像 2,2
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Right Button Board Replacement: 步骤 17 中的图像 1,2 PlayStation Vita Right Button Board Replacement: 步骤 17 中的图像 2,2
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Right Button Board Replacement: 步骤 18 中的图像 1,3 PlayStation Vita Right Button Board Replacement: 步骤 18 中的图像 2,3 PlayStation Vita Right Button Board Replacement: 步骤 18 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Right Button Board Replacement: 步骤 19 中的图像 1,3 PlayStation Vita Right Button Board Replacement: 步骤 19 中的图像 2,3 PlayStation Vita Right Button Board Replacement: 步骤 19 中的图像 3,3
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Right Button Board Replacement: 步骤 20 中的图像 1,3 PlayStation Vita Right Button Board Replacement: 步骤 20 中的图像 2,3 PlayStation Vita Right Button Board Replacement: 步骤 20 中的图像 3,3
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
结论
另外一个人完成了本指南。
Brittany McCrigler
于03/05/12注册
89,128 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,074篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 22
过去 30 天: 55
总计 7,948
