本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide takes you through the process of installing the rear panel. The rear panel houses the rear touch pad.
你所需要的
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
Slide the spuder between the right speaker and the rear casing.
Using a spudger, gently peel up the right speaker from the light adhesive connecting it to casing.
Remove the right speaker.
11等其他人完成本指南。
5条评论
I really enjoyed Your article ! I'm about to replace the touch pad, i got a Vita recently but it has some Heavy scuffs. I've seen the back touch pad has adhesive attached on it. I bought a replacement On Ebay. I'm not sure if the replacement has adhesive with it. If it doesn't what would be your guys Thoughts on what i should use?
lol you will need some kind of adhesive its called common sense if Sony use it you use it simple
TH3ORY -
In the part that remains after complete disassembly, what are the two double pins at the top for, which later come into contact with the motherboard? I already have a new panel, but it has absolutely nothing except this one contact in the lower right part ...
Those are wifi antennas. You can get it out put it in to the new panel.
