跳转到主内容
PlayStation Vita Directional Pad Replacement
你所需要的
  1. PlayStation Vita Directional Pad Replacement, Case Separation: 步骤 1 中的图像 1,2 PlayStation Vita Directional Pad Replacement, Case Separation: 步骤 1 中的图像 2,2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Directional Pad Replacement: 步骤 2 中的图像 1,3 PlayStation Vita Directional Pad Replacement: 步骤 2 中的图像 2,3 PlayStation Vita Directional Pad Replacement: 步骤 2 中的图像 3,3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Directional Pad Replacement: 步骤 3 中的图像 1,2 PlayStation Vita Directional Pad Replacement: 步骤 3 中的图像 2,2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Directional Pad Replacement: 步骤 4 中的图像 1,3 PlayStation Vita Directional Pad Replacement: 步骤 4 中的图像 2,3 PlayStation Vita Directional Pad Replacement: 步骤 4 中的图像 3,3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Directional Pad Replacement: 步骤 5 中的图像 1,2 PlayStation Vita Directional Pad Replacement: 步骤 5 中的图像 2,2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    One of the shoulder buttons fell out when I was doing this step, along with the piece holding it in place. They go back in just fine when reassembling but make sure that they are oriented properly, of course.
    klung - 回复
  6. PlayStation Vita Directional Pad Replacement: 步骤 6 中的图像 1,1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Directional Pad Replacement: 步骤 7 中的图像 1,1
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - 回复
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - 回复
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - 回复
    This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
    klung - 回复
    broke the white part
    Benaya Miller - 回复
  8. PlayStation Vita Directional Pad Replacement: 步骤 8 中的图像 1,1
    • Separate the front and rear cases.
  9. PlayStation Vita Directional Pad Replacement, Left Shoulder Button: 步骤 9 中的图像 1,3 PlayStation Vita Directional Pad Replacement, Left Shoulder Button: 步骤 9 中的图像 2,3 PlayStation Vita Directional Pad Replacement, Left Shoulder Button: 步骤 9 中的图像 3,3
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  10. PlayStation Vita Directional Pad Replacement: 步骤 10 中的图像 1,2 PlayStation Vita Directional Pad Replacement: 步骤 10 中的图像 2,2
    • Remove the translucent, plastic left shoulder button cover.
  11. PlayStation Vita Directional Pad Replacement: 步骤 11 中的图像 1,3 PlayStation Vita Directional Pad Replacement: 步骤 11 中的图像 2,3 PlayStation Vita Directional Pad Replacement: 步骤 11 中的图像 3,3
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
    broke the small black tab, what happens if I just go without it??
    Nicolas Porfirio - 回复
  12. PlayStation Vita Directional Pad Replacement: 步骤 12 中的图像 1,2 PlayStation Vita Directional Pad Replacement: 步骤 12 中的图像 2,2
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
    This step is unneccesary.
    Alexander Mayatsky - 回复
  13. PlayStation Vita Directional Pad Replacement, Left Button Board: 步骤 13 中的图像 1,2 PlayStation Vita Directional Pad Replacement, Left Button Board: 步骤 13 中的图像 2,2
    • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
    • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
    Este paso NO es necesario si tu PSVita no tiene lector de tarjeta SIM. Ve directamente al paso 15.
    Parappa The Rapper - 回复
  14. PlayStation Vita Directional Pad Replacement: 步骤 14 中的图像 1,3 PlayStation Vita Directional Pad Replacement: 步骤 14 中的图像 2,3 PlayStation Vita Directional Pad Replacement: 步骤 14 中的图像 3,3
    • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
    • Lift the SIM card reader off the back casing assembly.
    This board is not present in the Wifi only version, only the 3G/Wifi version.
    dodo - 回复
  15. PlayStation Vita Directional Pad Replacement: 步骤 15 中的图像 1,2 PlayStation Vita Directional Pad Replacement: 步骤 15 中的图像 2,2
    • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
    • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
  16. PlayStation Vita Directional Pad Replacement: 步骤 16 中的图像 1,2 PlayStation Vita Directional Pad Replacement: 步骤 16 中的图像 2,2
    • Use a spudger to lift up the tab on the large ZIF socket.
    • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
  17. PlayStation Vita Directional Pad Replacement: 步骤 17 中的图像 1,2 PlayStation Vita Directional Pad Replacement: 步骤 17 中的图像 2,2
    • Disconnect the white Wi-Fi antenna cable with a spudger.
    • Remove the Wi-Fi antenna cable.
    This connector isn't present in the Wifi only version, just the 3G/Wifi version.
    dodo - 回复
  18. PlayStation Vita Directional Pad Replacement: 步骤 18 中的图像 1,3 PlayStation Vita Directional Pad Replacement: 步骤 18 中的图像 2,3 PlayStation Vita Directional Pad Replacement: 步骤 18 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
    • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
    • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
    What is the loose looking cable in this photo?
    Dallon Verhaeghe - 回复
  19. PlayStation Vita Directional Pad Replacement: 步骤 19 中的图像 1,3 PlayStation Vita Directional Pad Replacement: 步骤 19 中的图像 2,3 PlayStation Vita Directional Pad Replacement: 步骤 19 中的图像 3,3
    • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
  20. PlayStation Vita Directional Pad Replacement, Directional Pad: 步骤 20 中的图像 1,3 PlayStation Vita Directional Pad Replacement, Directional Pad: 步骤 20 中的图像 2,3 PlayStation Vita Directional Pad Replacement, Directional Pad: 步骤 20 中的图像 3,3
    • Using tweezers, peel up and remove the directional pad.
结论
9等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
88,930 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,722篇指南
一条评论
I read this guide from the first to the20th step I haven't tried it yet though
brandon abney - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 112
总计 16,408
