跳转到主内容
PlayStation Vita Case Separation
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. PlayStation Vita Case Separation, Case Separation: 步骤 1 中的图像 1,2 PlayStation Vita Case Separation, Case Separation: 步骤 1 中的图像 2,2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Case Separation: 步骤 2 中的图像 1,3 PlayStation Vita Case Separation: 步骤 2 中的图像 2,3 PlayStation Vita Case Separation: 步骤 2 中的图像 3,3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Case Separation: 步骤 3 中的图像 1,2 PlayStation Vita Case Separation: 步骤 3 中的图像 2,2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Case Separation: 步骤 4 中的图像 1,3 PlayStation Vita Case Separation: 步骤 4 中的图像 2,3 PlayStation Vita Case Separation: 步骤 4 中的图像 3,3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Case Separation: 步骤 5 中的图像 1,2 PlayStation Vita Case Separation: 步骤 5 中的图像 2,2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Case Separation: 步骤 6 中的图像 1,1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Case Separation: 步骤 7 中的图像 1,1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Case Separation: 步骤 8 中的图像 1,1
    • Separate the front and rear cases.
结论
Brittany McCrigler
于03/05/12注册
89,017 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,198篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 10
总计 312
