跳转到主内容
PlayStation VR Processor Unit Thermal Pad / Fan Replacement
你所需要的
  1. PlayStation VR Processor Unit Thermal Pad / Fan Replacement, Processor Unit Thermal Pad: 步骤 1 中的图像 1,2 PlayStation VR Processor Unit Thermal Pad / Fan Replacement, Processor Unit Thermal Pad: 步骤 1 中的图像 2,2
    • Place the PlayStation VR processor unit with the I/O (back) side facing up.
    • Peel the sticker up with a fingernail or a pry tool.
    • Remove the single J0 screw.
    • Place the screw in a parts tray to keep it organized.
  2. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: 步骤 2 中的图像 1,3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: 步骤 2 中的图像 2,3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: 步骤 2 中的图像 3,3
    • Use an opening tool to separate the bottom cover from the top.
  3. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: 步骤 3 中的图像 1,3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: 步骤 3 中的图像 2,3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: 步骤 3 中的图像 3,3
    • Remove the eight J0 screws.
    • Place the screws in the parts tray
    • Use your tweezers to disconnect the fan connector from the motherboard
    • If the fan needs to be replaced, stop here and follow in reverse.
    • Fan details.
    • Brand: Nidec
    • Model and dimensions: U35x05m 52aa7-56j14
    • Power: 5v and .18a
  4. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: 步骤 4 中的图像 1,3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: 步骤 4 中的图像 2,3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: 步骤 4 中的图像 3,3
    • Use a spudger or a fingernail to lift the pcb in the direction highlighted
    • Gently separate the metal plate from pcb
    • Replace the thermal paste if needed.
    • Use a fingernail or a pry tool to see if the thermal pad is still soft. that means it still conducts heat. if hard, remove and replace the thermal pad
结论
3等其他人完成本指南。
Kalib Ellery
于10/17/16注册
492 声望
创作了2篇指南
3条评论
Hi, is thermal pads being dry could be the reason for this processing unit not turning on? It lits the light for quick millisecond and goes out as i connect the barrel jack. :( I couldn't find any fix yet
Chandu Samarasekara - 回复
Is it neccessary to replace the thermal pad with another pad , or may I use normal thermal paste?
DasNexus - 回复
It must be replaced with another new thermal pad of the same thickness, in this case a 2mm pad. If you use thermal paste, there will be a lot of space between the heatsink and the chip, which could cause failures and overheating.
Rixson Perez -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 31
过去 30 天: 91
总计 2,340
