跳转到主内容
PlayStation VR Processor Unit Cooling Fan Replacement
你所需要的
  1. PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 步骤 1 中的图像 1,3 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 步骤 1 中的图像 2,3 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 步骤 1 中的图像 3,3
    • On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
  2. PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 2 中的图像 1,3 PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 2 中的图像 2,3 PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 2 中的图像 3,3
    • Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
    • Unscrew the 6mm screw with a PH #000 screwdriver.
  3. PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 3 中的图像 1,2 PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 3 中的图像 2,2
    • Slide the panel back into place.
  4. PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 4 中的图像 1,3 PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 4 中的图像 2,3 PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 4 中的图像 3,3
    • Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
    • You will probably need to lift it on both sides in order for the panel to come loose.
  5. PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 5 中的图像 1,1
    • Turn the console over.
    • Unscrew the two 9 mm screws with a PH #000 screwdriver.
  6. PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 6 中的图像 1,2 PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 6 中的图像 2,2
    • With the plastic opening tool, carefully pry the console shell panel free and lift it away.
  7. PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 7 中的图像 1,2 PlayStation VR Processor Unit Cooling Fan Replacement: 步骤 7 中的图像 2,2
    • Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
    • Carefully lift the fan and its wiring from the device.
    • Be mindful of damaging the wires.
    • Take care to keep your fingers away from the fan blades.
结论
8等其他人完成本指南。
Sarah Shand
于02/20/17注册
1,885 声望
创作了7篇指南
团队
USF Tampa, Team S3-G1, Sullivan Spring 2017 USF Tampa, Team S3-G1, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S3G1
3 名成员
创作了13篇指南
4条评论
Where do I get a replacement fan tho?
Ponos King - 回复
I think is a 3x3 cm fan, alliexpres has some, but what voltage?
crus - 回复
5V is what i have read
Ethan Amos -
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
herossuperman - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 64
总计 8,762
