跳转到主内容
PlayStation One Mother Board Replacement
你所需要的
  1. PlayStation One Mother Board Replacement, Upper Case: 步骤 1 中的图像 1,1
    • Remove all cables plugged into the PlayStation.
  2. PlayStation One Mother Board Replacement: 步骤 2 中的图像 1,2 PlayStation One Mother Board Replacement: 步骤 2 中的图像 2,2
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. PlayStation One Mother Board Replacement: 步骤 3 中的图像 1,1
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. PlayStation One Mother Board Replacement: 步骤 4 中的图像 1,2 PlayStation One Mother Board Replacement: 步骤 4 中的图像 2,2
    • Lift up and remove the upper case.
  5. PlayStation One Mother Board Replacement, Laser Assembly: 步骤 5 中的图像 1,3 PlayStation One Mother Board Replacement, Laser Assembly: 步骤 5 中的图像 2,3 PlayStation One Mother Board Replacement, Laser Assembly: 步骤 5 中的图像 3,3
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
  6. PlayStation One Mother Board Replacement, Mother Board: 步骤 6 中的图像 1,2 PlayStation One Mother Board Replacement, Mother Board: 步骤 6 中的图像 2,2
    • remove the metal plate
    well well a modded ps one hahah
    Bernabe Alvarez - 回复
  7. PlayStation One Mother Board Replacement: 步骤 7 中的图像 1,3 PlayStation One Mother Board Replacement: 步骤 7 中的图像 2,3 PlayStation One Mother Board Replacement: 步骤 7 中的图像 3,3
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
结论
14等其他人完成本指南。
Marjorie
于12/23/13注册
2,273 声望
创作了11篇指南
一条评论
I think that the GPU in my PS One is going bad (screen flickers green and pink on occasion but it is becoming more frequent). Would replacing the motherboard fix this? That is, is the GPU stored on the motherboard?
Eric Rosenberg - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 103
总计 12,844
