跳转到主内容
PlayStation Move LED Light Replacement
你所需要的
  1. PlayStation Move LED Light Replacement, Battery: 步骤 1 中的图像 1,3 PlayStation Move LED Light Replacement, Battery: 步骤 1 中的图像 2,3 PlayStation Move LED Light Replacement, Battery: 步骤 1 中的图像 3,3
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
  2. PlayStation Move LED Light Replacement: 步骤 2 中的图像 1,2 PlayStation Move LED Light Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
  3. PlayStation Move LED Light Replacement: 步骤 3 中的图像 1,2 PlayStation Move LED Light Replacement: 步骤 3 中的图像 2,2
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
  4. PlayStation Move LED Light Replacement: 步骤 4 中的图像 1,3 PlayStation Move LED Light Replacement: 步骤 4 中的图像 2,3 PlayStation Move LED Light Replacement: 步骤 4 中的图像 3,3
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  5. PlayStation Move LED Light Replacement: 步骤 5 中的图像 1,2 PlayStation Move LED Light Replacement: 步骤 5 中的图像 2,2
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  6. PlayStation Move LED Light Replacement: 步骤 6 中的图像 1,2 PlayStation Move LED Light Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  7. PlayStation Move LED Light Replacement: 步骤 7 中的图像 1,3 PlayStation Move LED Light Replacement: 步骤 7 中的图像 2,3 PlayStation Move LED Light Replacement: 步骤 7 中的图像 3,3
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  8. PlayStation Move LED Light Replacement: 步骤 8 中的图像 1,2 PlayStation Move LED Light Replacement: 步骤 8 中的图像 2,2
    • Gently pull on the white piece connecting the battery and the connector.
  9. PlayStation Move LED Light Replacement, Motherboard: 步骤 9 中的图像 1,3 PlayStation Move LED Light Replacement, Motherboard: 步骤 9 中的图像 2,3 PlayStation Move LED Light Replacement, Motherboard: 步骤 9 中的图像 3,3
    • Remove the five 1.2 mm screws from upper portion of the controller.
    • If you are replacing the trigger button, continue to step 13.
  10. PlayStation Move LED Light Replacement: 步骤 10 中的图像 1,2 PlayStation Move LED Light Replacement: 步骤 10 中的图像 2,2
    • Remove the two 1.2mm Phillips #1 screws.
  11. PlayStation Move LED Light Replacement: 步骤 11 中的图像 1,3 PlayStation Move LED Light Replacement: 步骤 11 中的图像 2,3 PlayStation Move LED Light Replacement: 步骤 11 中的图像 3,3
    • Cautiously remove the circular white piece at the top without removing the LED inside.
  12. PlayStation Move LED Light Replacement: 步骤 12 中的图像 1,3 PlayStation Move LED Light Replacement: 步骤 12 中的图像 2,3 PlayStation Move LED Light Replacement: 步骤 12 中的图像 3,3
    • Remove the blue strip that is connected to the trigger button from the motherboard.
    • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
  13. PlayStation Move LED Light Replacement: 步骤 13 中的图像 1,2 PlayStation Move LED Light Replacement: 步骤 13 中的图像 2,2
    • Remove the trigger button from the controller.
  14. PlayStation Move LED Light Replacement: 步骤 14 中的图像 1,3 PlayStation Move LED Light Replacement: 步骤 14 中的图像 2,3 PlayStation Move LED Light Replacement: 步骤 14 中的图像 3,3
    • Remove the LED light by removing the white strip.
    • If you are replacing the LED light, continue to Step 17.
  15. PlayStation Move LED Light Replacement: 步骤 15 中的图像 1,2 PlayStation Move LED Light Replacement: 步骤 15 中的图像 2,2
    • Remove the motherboard from the plastic case.
  16. PlayStation Move LED Light Replacement, LED Light: 步骤 16 中的图像 1,2 PlayStation Move LED Light Replacement, LED Light: 步骤 16 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Insert tweezers between the LED case and the LED clear plastic cover.
    • Lift the edge of the LED clear cover clip to be able to remove the cover.
    • Repeat the previous step to the other side.
    • Remove the LED cover.
  17. PlayStation Move LED Light Replacement: 步骤 17 中的图像 1,2 PlayStation Move LED Light Replacement: 步骤 17 中的图像 2,2
    • Remove the LED board using a blue opening tool to lift the board.
    • After the board is loose, remove the LED board.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 的会员
USFT-PASSMORE-F16S3G3
4 名成员
创作了8篇指南
3条评论
Okay, going to try this. Do I have to solder the white strip back onto the board?
randallrigdonjr - 回复
did you ever get this done? need to know the same.
[deleted] -
très clair, mais où trouver une led ? et en enlevant le cable de la led, il faut le dessourder, non ?
Pierrot - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 42
总计 4,280
