跳转到主内容
加入维修社区 - 创建账户
PlayStation Motherboard Replacement
你所需要的
    1. PlayStation Motherboard Replacement, Open the Console: 步骤 1 中的图像 1,1
      • Before you begin, make sure the console is turned off and unplugged.
      • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
      添加评论
    2. PlayStation Motherboard Replacement: 步骤 2 中的图像 1,2 PlayStation Motherboard Replacement: 步骤 2 中的图像 2,2
      • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
      询问修复机器人
      添加评论
    1. PlayStation Motherboard Replacement, Remove the Controller Ports: 步骤 3 中的图像 1,1
      • Remove five Phillips #1 screws securing the metal shield to the controller ports:
      • Two 14 mm screws
      • Three 8 mm screws
      添加评论
    2. PlayStation Motherboard Replacement: 步骤 4 中的图像 1,2 PlayStation Motherboard Replacement: 步骤 4 中的图像 2,2
      • Lift the metal shield straight up to remove it.
      添加评论
    3. PlayStation Motherboard Replacement: 步骤 5 中的图像 1,2 PlayStation Motherboard Replacement: 步骤 5 中的图像 2,2
      • Pull the controller port's ribbon cable straight up and out of its socket on the motherboard to disconnect it.
      添加评论
    4. PlayStation Motherboard Replacement: 步骤 6 中的图像 1,2 PlayStation Motherboard Replacement: 步骤 6 中的图像 2,2
      • Lift the controller ports straight up and out of the bottom case.
      询问修复机器人
      添加评论
    1. PlayStation Motherboard Replacement, Remove the Optical Drive: 步骤 7 中的图像 1,2 PlayStation Motherboard Replacement, Remove the Optical Drive: 步骤 7 中的图像 2,2
      • Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
      添加评论
    2. PlayStation Motherboard Replacement: 步骤 8 中的图像 1,3 PlayStation Motherboard Replacement: 步骤 8 中的图像 2,3 PlayStation Motherboard Replacement: 步骤 8 中的图像 3,3
      • Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
      • You'll hear a faint click noise when unlocking the connector. Make sure not to apply too much pressure when lifting up on the connector with the spudger, or else damage may result.
      • Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
      添加评论
    3. PlayStation Motherboard Replacement: 步骤 9 中的图像 1,2 PlayStation Motherboard Replacement: 步骤 9 中的图像 2,2
      • Lift the optical drive straight up to remove it.
      询问修复机器人
      添加评论
    1. PlayStation Motherboard Replacement, Unplug the Power Supply: 步骤 10 中的图像 1,2 PlayStation Motherboard Replacement, Unplug the Power Supply: 步骤 10 中的图像 2,2
      • Pull the power supply cable straight up and out of its socket on the motherboard to disconnect it.
      询问修复机器人
      添加评论
    2. PlayStation Motherboard Replacement, Remove the Motherboard's Metal Shield: 步骤 11 中的图像 1,1
      • Remove the five 14 mm-long Phillips #1 screws from the motherboard's metal shield.
      询问修复机器人
      添加评论
    3. PlayStation Motherboard Replacement: 步骤 12 中的图像 1,3 PlayStation Motherboard Replacement: 步骤 12 中的图像 2,3 PlayStation Motherboard Replacement: 步骤 12 中的图像 3,3
      • From the left side, lift up the metal shield and rotate it about its right edge, opening it like a book.
      • There may be strips of tape holding the right side of the metal shield to the case, necessitating this kind of removal procedure. If there isn't tape, you can simply lift the shield straight up to remove it.
      询问修复机器人
      添加评论
    4. PlayStation Motherboard Replacement, Remove the Motherboard: 步骤 13 中的图像 1,1
      • Remove the three 14 mm-long Phillips #1 screws securing the motherboard to the bottom case.
      询问修复机器人
      添加评论
    5. PlayStation Motherboard Replacement: 步骤 14 中的图像 1,2 PlayStation Motherboard Replacement: 步骤 14 中的图像 2,2
      • Lift the motherboard out of the bottom case.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
32等其他人完成本指南。
Craig Lloyd
于02/10/16注册
42,981 声望
创作了82篇指南
3指南评论
Hi there.
Here i can buy that copper tape from the right of the metal shield ?
Thkx in adv
Haitham - 回复 分享
Excelente guía, esto ayuda a muchos para aprender a reparar y no hacer gastos innecesarios.
aldrin peñate - 回复 分享
Thanks for sharing. Could you make a tutorial about common Board damage and how to fix it?
Alejandro Pérez - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 57
过去 30 天: 195
总计 31,248
