跳转到主内容
PlayStation Controller Ports Replacement
你所需要的
  1. PlayStation Controller Ports Replacement, Open the Console: 步骤 1 中的图像 1,1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
  2. PlayStation Controller Ports Replacement: 步骤 2 中的图像 1,2 PlayStation Controller Ports Replacement: 步骤 2 中的图像 2,2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. PlayStation Controller Ports Replacement, Remove the Controller Ports: 步骤 3 中的图像 1,1
    • Remove five Phillips #1 screws securing the metal shield to the controller ports:
    • Two 14 mm screws
    • Three 8 mm screws
  4. PlayStation Controller Ports Replacement: 步骤 4 中的图像 1,2 PlayStation Controller Ports Replacement: 步骤 4 中的图像 2,2
    • Lift the metal shield straight up to remove it.
  5. PlayStation Controller Ports Replacement: 步骤 5 中的图像 1,2 PlayStation Controller Ports Replacement: 步骤 5 中的图像 2,2
    • Pull the controller port's ribbon cable straight up and out of its socket on the motherboard to disconnect it.
  6. PlayStation Controller Ports Replacement: 步骤 6 中的图像 1,2 PlayStation Controller Ports Replacement: 步骤 6 中的图像 2,2
    • Lift the controller ports straight up and out of the bottom case.
结论
11等其他人完成本指南。
Craig Lloyd
于02/10/16注册
35,415 声望
创作了82篇指南
5条评论
I try replacing the controller and still wouldn't play memory cards.
redevil19 - 回复
I changed the controller port but the psx still doesn't recognize any controller. Both controller port and ribbon cable work perfect in other console. I wonder which components on the mother board are related with the controller ports so I can check them with a tester.
Daniel Prieto - 回复
I replaced the PS605 fuse and now the controllers work again! Thanks to this video https://www.youtube.com/watch?v=HdULot5F...
Daniel Prieto -
I'm having a weird issue, it will read in second do
Port but not the first. Changed controller port and still having the same issue
michael wise - 回复
The problem on mine is where I can’t use memory card slot 1 but Slot 2 works and is what I use but I would like to used slot 1 and have more than just a single memory card for playing games on it.
Travirus - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 31
过去 30 天: 155
总计 26,360
