跳转到主内容
PlayStation Classic Controller Port Replacement
你所需要的
  1. PlayStation Classic Controller Port Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Flip the console so its back is facing up.
  2. PlayStation Classic Controller Port Replacement: 步骤 2 中的图像 1,1
    • Remove the five 3mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. PlayStation Classic Controller Port Replacement: 步骤 3 中的图像 1,3 PlayStation Classic Controller Port Replacement: 步骤 3 中的图像 2,3 PlayStation Classic Controller Port Replacement: 步骤 3 中的图像 3,3
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. PlayStation Classic Controller Port Replacement: 步骤 4 中的图像 1,1
    • Unscrew the motherboard's five 3mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. PlayStation Classic Controller Port Replacement: 步骤 5 中的图像 1,3 PlayStation Classic Controller Port Replacement: 步骤 5 中的图像 2,3 PlayStation Classic Controller Port Replacement: 步骤 5 中的图像 3,3
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. PlayStation Classic Controller Port Replacement: 步骤 6 中的图像 1,3 PlayStation Classic Controller Port Replacement: 步骤 6 中的图像 2,3 PlayStation Classic Controller Port Replacement: 步骤 6 中的图像 3,3
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
  7. PlayStation Classic Controller Port Replacement, Controller Port: 步骤 7 中的图像 1,2 PlayStation Classic Controller Port Replacement, Controller Port: 步骤 7 中的图像 2,2
    • Identify the damaged or faulty controller port and simply use your fingers to remove.
结论
另外一个人完成了本指南。
Maxwell Webb
于04/22/19注册
685 声望
创作了5篇指南
团队
Cal Poly, Team S2-G8, Maness Spring 2019 Cal Poly, Team S2-G8, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G8
2 名成员
创作了23篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 37
总计 2,079
