跳转到主内容
PlayStation 4 Wi-Fi Antenna Replacement
你所需要的
  1. PlayStation 4 Wi-Fi Antenna Replacement, Remove Stickers: 步骤 1 中的图像 1,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove Stickers: 步骤 1 中的图像 2,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove Stickers: 步骤 1 中的图像 3,3
    • Using a dental pick or something similar, remove the three stickers on the bottom casing.
  2. PlayStation 4 Wi-Fi Antenna Replacement, Remove Bottom Case Screws: 步骤 2 中的图像 1,2 PlayStation 4 Wi-Fi Antenna Replacement, Remove Bottom Case Screws: 步骤 2 中的图像 2,2
    • Remove the three black screws in the bottom case using a T9 security torx bit.
  3. PlayStation 4 Wi-Fi Antenna Replacement, Remove Bottom Case: 步骤 3 中的图像 1,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove Bottom Case: 步骤 3 中的图像 2,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove Bottom Case: 步骤 3 中的图像 3,3
    • Pull up on one side of the case, then the other then slide the case back. It will then be free from the rest of the console.
  4. PlayStation 4 Wi-Fi Antenna Replacement, Remove Power Supply Screws: 步骤 4 中的图像 1,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove Power Supply Screws: 步骤 4 中的图像 2,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove Power Supply Screws: 步骤 4 中的图像 3,3
    • Remove the five screws that secure the power supply. There are two PH1 and three T9 torx security screws.
  5. PlayStation 4 Wi-Fi Antenna Replacement, Remove Power Supply: 步骤 5 中的图像 1,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove Power Supply: 步骤 5 中的图像 2,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove Power Supply: 步骤 5 中的图像 3,3
    • First pull up on one side of the power supply, then pull up on the other side. Gently but firmly wiggle it out.
    • Be careful as you pull up on the power supply as it is still connected with a connector from the motherboard.
  6. PlayStation 4 Wi-Fi Antenna Replacement, Disconnect WiFi Antenna: 步骤 6 中的图像 1,3 PlayStation 4 Wi-Fi Antenna Replacement, Disconnect WiFi Antenna: 步骤 6 中的图像 2,3 PlayStation 4 Wi-Fi Antenna Replacement, Disconnect WiFi Antenna: 步骤 6 中的图像 3,3
    • The power supply can lifted out and rotated down and set on the workbench.
    • Be very careful not to pull on the power supply as it will still be connected to the motherboard.
    • Use ESD-safe tweezers to carefully disconnect the wi-fi antenna by pulling it straight up.
    • Be be careful not to apply too much force on the WiFi connector as it can break off.
    • After the WiFi cable is disconnected, de-route the cable from the two clips and under the optical drive cable.
  7. PlayStation 4 Wi-Fi Antenna Replacement, Remove WiFi Screw & WiFi Antenna: 步骤 7 中的图像 1,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove WiFi Screw & WiFi Antenna: 步骤 7 中的图像 2,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove WiFi Screw & WiFi Antenna: 步骤 7 中的图像 3,3
    • Remove the one torx T9 security screw from the WiFi antenna located at the front of the console.
    • The WiFi Antenna can now be fully removed from the PS4.
结论
Be sure to route the WiFi antenna cable the same way as it was routed before disassembly. Then take a break and have some ice cream!
89等其他人完成本指南。
TronicsFix
于11/06/13注册
34,811 声望
创作了5篇指南
团队
TronicsFix TronicsFix 的会员
Business
1 名成员
创作了21篇指南
111条评论
Took me about 10mins with this guide. Super easy. New parts in and working wonderfully. Ty ifixit!
luckycha87 - 回复
My wireless controlers wasn't recognised. I change the WiFi connector but this problem is not resoleved yet.
Frederic Morelli - 回复
Hi Frederic! Have you tried resetting the controller? Have you tried any other controllers to see if they work? Also, are you sure the battery in your controller is good and it's charged up?
TronicsFix -
Hello my controller has a hard time working from 4 feet away from my console and disconnecting. Im thinking of doing this hopefully it works. Is the bluetooth and wifi part the same thing because my wifi doesnt seem to pick up my wireless router.
ludracing - 回复
Yes, the wifi and bluetooth antenna is the same.
TronicsFix -
添加评论
浏览统计数据:
过去 24 小时: 39
过去 7 天: 248
过去 30 天: 1,107
总计 165,108
