跳转到主内容
加入维修社区 - 创建账户
PlayStation 4 Wi-Fi Antenna Replacement
你所需要的
    1. PlayStation 4 Wi-Fi Antenna Replacement, Flip over the PS4: 步骤 1 中的图像 1,1
      • Flip the PS4 upside-down with the back side facing towards you.
      询问修复机器人
      添加评论
    2. PlayStation 4 Wi-Fi Antenna Replacement, Remove the warranty stickers: 步骤 2 中的图像 1,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove the warranty stickers: 步骤 2 中的图像 2,3 PlayStation 4 Wi-Fi Antenna Replacement, Remove the warranty stickers: 步骤 2 中的图像 3,3
      在这个步骤中使用的工具:
      • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
      询问修复机器人
      添加评论
    3. PlayStation 4 Wi-Fi Antenna Replacement, Remove the plastic screw covers: 步骤 3 中的图像 1,2 PlayStation 4 Wi-Fi Antenna Replacement, Remove the plastic screw covers: 步骤 3 中的图像 2,2
      • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
      添加评论
    4. PlayStation 4 Wi-Fi Antenna Replacement, Remove the rear case screws: 步骤 4 中的图像 1,2 PlayStation 4 Wi-Fi Antenna Replacement, Remove the rear case screws: 步骤 4 中的图像 2,2
      • Remove the four 7.2 mm T8 Torx security screws on the back of the PS4.
      添加评论
    5. PlayStation 4 Wi-Fi Antenna Replacement, Remove the lower case: 步骤 5 中的图像 1,2 PlayStation 4 Wi-Fi Antenna Replacement, Remove the lower case: 步骤 5 中的图像 2,2
      • Use your thumbs to lift the lower case up and off the PS4.
      • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
      添加评论
    6. PlayStation 4 Wi-Fi Antenna Replacement: 步骤 6 中的图像 1,2 PlayStation 4 Wi-Fi Antenna Replacement: 步骤 6 中的图像 2,2
      • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
      • If your connector feels stuck, use a spudger to gently pry the connector out.
      添加评论
    1. PlayStation 4 Wi-Fi Antenna Replacement, Remove the power supply unit: 步骤 7 中的图像 1,2 PlayStation 4 Wi-Fi Antenna Replacement, Remove the power supply unit: 步骤 7 中的图像 2,2
      • Remove three 9.7 mm-long TR8 Torx security screws.
      • Remove two 41 mm-long Phillips screws and brackets.
      询问修复机器人
      添加评论
    2. PlayStation 4 Wi-Fi Antenna Replacement: 步骤 8 中的图像 1,3 PlayStation 4 Wi-Fi Antenna Replacement: 步骤 8 中的图像 2,3 PlayStation 4 Wi-Fi Antenna Replacement: 步骤 8 中的图像 3,3
      • Lift the power supply straight up and out of the PS4.
      • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
      • During reassembly, ensure the prongs are aligned, then press the power supply into place.
      添加评论
    1. PlayStation 4 Wi-Fi Antenna Replacement, Remove the Wi-Fi antenna: 步骤 9 中的图像 1,2 PlayStation 4 Wi-Fi Antenna Replacement, Remove the Wi-Fi antenna: 步骤 9 中的图像 2,2
      • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
      添加评论
    2. PlayStation 4 Wi-Fi Antenna Replacement: 步骤 10 中的图像 1,3 PlayStation 4 Wi-Fi Antenna Replacement: 步骤 10 中的图像 2,3 PlayStation 4 Wi-Fi Antenna Replacement: 步骤 10 中的图像 3,3
      在这个步骤中使用的工具:
      • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
      询问修复机器人
      添加评论
    3. PlayStation 4 Wi-Fi Antenna Replacement: 步骤 11 中的图像 1,3 PlayStation 4 Wi-Fi Antenna Replacement: 步骤 11 中的图像 2,3 PlayStation 4 Wi-Fi Antenna Replacement: 步骤 11 中的图像 3,3
      • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
      询问修复机器人
      添加评论
    4. PlayStation 4 Wi-Fi Antenna Replacement: 步骤 12 中的图像 1,2 PlayStation 4 Wi-Fi Antenna Replacement: 步骤 12 中的图像 2,2
      • Remove the 9.7 mm Torx security screw securing the antenna.
      添加评论
    5. PlayStation 4 Wi-Fi Antenna Replacement: 步骤 13 中的图像 1,2 PlayStation 4 Wi-Fi Antenna Replacement: 步骤 13 中的图像 2,2
      • Remove the Wi-Fi antenna.
      添加评论
结论
取消:我没有完成这个指南。
95等其他人完成本指南。
Sam Omiotek
于02/25/19注册
100,229 声望
创作了289篇指南
112指南评论
Took me about 10mins with this guide. Super easy. New parts in and working wonderfully. Ty ifixit!
luckycha87 - 回复 分享
My wireless controlers wasn't recognised. I change the WiFi connector but this problem is not resoleved yet.
Frederic Morelli - 回复 分享
Hi Frederic! Have you tried resetting the controller? Have you tried any other controllers to see if they work? Also, are you sure the battery in your controller is good and it's charged up?
TronicsFix - 回复 分享
Hello my controller has a hard time working from 4 feet away from my console and disconnecting. Im thinking of doing this hopefully it works. Is the bluetooth and wifi part the same thing because my wifi doesnt seem to pick up my wireless router.
ludracing - 回复 分享
Yes, the wifi and bluetooth antenna is the same.
TronicsFix - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 26
过去 7 天: 181
过去 30 天: 650
总计 192,019
