跳转到主内容
PlayStation 4 Slim Power Supply Replacement
你所需要的
  1. PlayStation 4 Slim Power Supply Replacement, Bottom Cover: 步骤 1 中的图像 1,3 PlayStation 4 Slim Power Supply Replacement, Bottom Cover: 步骤 1 中的图像 2,3 PlayStation 4 Slim Power Supply Replacement, Bottom Cover: 步骤 1 中的图像 3,3
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Power Supply Replacement: 步骤 2 中的图像 1,2 PlayStation 4 Slim Power Supply Replacement: 步骤 2 中的图像 2,2
    • Unscrew and remove the now exposed 5.0mm screw using a T8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Power Supply Replacement: 步骤 3 中的图像 1,3 PlayStation 4 Slim Power Supply Replacement: 步骤 3 中的图像 2,3 PlayStation 4 Slim Power Supply Replacement: 步骤 3 中的图像 3,3
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
  4. PlayStation 4 Slim Power Supply Replacement, Power Supply: 步骤 4 中的图像 1,3 PlayStation 4 Slim Power Supply Replacement, Power Supply: 步骤 4 中的图像 2,3 PlayStation 4 Slim Power Supply Replacement, Power Supply: 步骤 4 中的图像 3,3
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
  5. PlayStation 4 Slim Power Supply Replacement: 步骤 5 中的图像 1,3 PlayStation 4 Slim Power Supply Replacement: 步骤 5 中的图像 2,3 PlayStation 4 Slim Power Supply Replacement: 步骤 5 中的图像 3,3
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  6. PlayStation 4 Slim Power Supply Replacement: 步骤 6 中的图像 1,1
    • Remove the four 16mm Philips screws holding the power supply in place.
  7. PlayStation 4 Slim Power Supply Replacement: 步骤 7 中的图像 1,2 PlayStation 4 Slim Power Supply Replacement: 步骤 7 中的图像 2,2
    • Remove the metal sheet from the top of of the power supply by grabbing and lifting up with your hands.
  8. PlayStation 4 Slim Power Supply Replacement: 步骤 8 中的图像 1,2 PlayStation 4 Slim Power Supply Replacement: 步骤 8 中的图像 2,2
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
  9. PlayStation 4 Slim Power Supply Replacement: 步骤 9 中的图像 1,2 PlayStation 4 Slim Power Supply Replacement: 步骤 9 中的图像 2,2
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  10. PlayStation 4 Slim Power Supply Replacement: 步骤 10 中的图像 1,3 PlayStation 4 Slim Power Supply Replacement: 步骤 10 中的图像 2,3 PlayStation 4 Slim Power Supply Replacement: 步骤 10 中的图像 3,3
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
  11. PlayStation 4 Slim Power Supply Replacement: 步骤 11 中的图像 1,3 PlayStation 4 Slim Power Supply Replacement: 步骤 11 中的图像 2,3 PlayStation 4 Slim Power Supply Replacement: 步骤 11 中的图像 3,3
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
结论
70等其他人完成本指南。
Hernan Rodriguez
于01/24/18注册
3,642 声望
创作了3篇指南
团队
Cal Poly, Team S19-G4, Livingston Winter 2018 Cal Poly, Team S19-G4, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S19G4
4 名成员
创作了35篇指南
6条评论
Can the N15-160P1A power supply work on a PS4 system that originally came with N17-160P1A?
derasky4u - 回复
My PS4 not turning on
Khai Stering - 回复
This was awesome. Thanks for the assist
Christopher Gorgon - 回复
I need help figuring out what I did to my ps4 and what needs replacement I had the new nba 2k 22 in the disc drive and the game was partly finished downloading so as it was doing that I brought shinobi striker which I previously had to use someone’s account to play it so the game popped up as light so I deleted it the first time and redownloaded it and it still said lite so then I deleted again but this time I double tapped the PlayStation button and it went to Home Screen slowed down then froze so I unplugged it plugged it back up and it wouldn’t turn on
Deontay - 回复
My PS4 runs for 10 minutes and turns off again and again
HITESH MAKWANA - 回复
添加评论
浏览统计数据:
过去 24 小时: 38
过去 7 天: 211
过去 30 天: 1,153
总计 92,519
