跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
PlayStation 4 Slim 电源更换
你所需要的
  1. PlayStation 4 Slim 电源更换, 底盖: 步骤 1 中的图像 1,3 PlayStation 4 Slim 电源更换, 底盖: 步骤 1 中的图像 2,3 PlayStation 4 Slim 电源更换, 底盖: 步骤 1 中的图像 3,3
    • 找到机器后面三个接口旁边的塑料保修警告标签。
    • 用Spudger撬棒揭下保修标签。
    • 移除保修标签并不会意味着您放弃了保修。
    Remove the screw directly to the left of that one in the picture as well. Should be silver.
    Elizabeth Johnson - 回复
    ihr seid so ein scheiß haufen das stimmt über haubt nix
    Toaster 95 - 回复
    einfach alles stimmt nicht
    Toaster 95 - 回复
  2. PlayStation 4 Slim 电源更换: 步骤 2 中的图像 1,2 PlayStation 4 Slim 电源更换: 步骤 2 中的图像 2,2
    • 沿顺时针方向,用T8安全螺丝刀,拧下藏在保修标签后长为5毫米的螺丝。
    Are you SURE that it’s counter-clockwise?
    The Stuff - 回复
    Try T9. Fits better.
    Otter - 回复
    T8 fits like a glove for me
    Daniel Henderson -
    Is there anything else you can use
    randomweeb - 回复
    A small flathead screwdriver will work
    shawng6363 -
    There is a small metal rod in the middle of the screw that isn’t allowing my t8 inside. Any insight on this?
    gavinstoutconner@icloud.com - 回复
    Some T8 bits have a hole in the middle that will allow that rod to go through; some do not. If you have a set of multiple bits, check if there are any others labeled T8 or TR8 with that hole in the middle.
    Nicholas -
    There is a metal thing inside of the screw slot any insite on this?
    Tristan York - 回复
  3. PlayStation 4 Slim 电源更换: 步骤 3 中的图像 1,3 PlayStation 4 Slim 电源更换: 步骤 3 中的图像 2,3 PlayStation 4 Slim 电源更换: 步骤 3 中的图像 3,3
    • 将您的PS4 Slim倒置,使刚刚拧下来的螺丝的那一面面向您。
    • 用手指从两个面向您的边角撬开底盖。
    • 打开它可能需要些微的力,当您将底盖和设备分离时,您将会听到灰常大的清脆的声音。
    • 向后滑动并且抬起底盖就可以移除它了。
    It says to place it upside down, but didn't you do so in the previous step? I've been trying to unscrew the screw with my screwdriver that I got from here and if I had to had the system right side up, I'm afraid I might've stripped the screw from all the force I tried to use to get the screw out that will NOT budge. It didn't even move the slightest after removing the warranty sticker.
    Vidal Santos - 回复
    There is a single clip on the left side about 5cms in, and another clip on the right side equidistant to the one on the other side. Jamming a spudger in there first, and lifting those clips helped, and then I had to slide down to lift a total of 4 clips on each side (each about 4cms apart). Then push the cover away from you, if that makes more sense than “sliding it towards the back corners”, since the back corners are technically facing you.
    Emil Fisk - 回复
    It would be easier if you just lifted the top cover of the PS4.
    Poobler - 回复
    The earlier comment by Emil Fisk is spot-on. I found it impossible to remove the cover without first using a spudger to release the four clips on each side.
    midahed - 回复
    I saw many video and tried it my self, you have to remove the hard disc before removing any cover.
    Bahaa CHEBLI - 回复
  4. PlayStation 4 Slim 电源更换, 电源: 步骤 4 中的图像 1,3 PlayStation 4 Slim 电源更换, 电源: 步骤 4 中的图像 2,3 PlayStation 4 Slim 电源更换, 电源: 步骤 4 中的图像 3,3
    • 令PlayStation 4 Slim的右侧,即印有PS标志的一侧朝上放置,并将带有“SONY”和“PS4”字样的一面朝向您。
    • 在朝向你的一侧用手指将顶盖掰开。
    • 打开顶盖需要用不小的力气,而且在打开时卡扣会发出很大的声音。
    • 沿着顶盖向后打开剩余的卡扣并最终移除顶盖。
    Undo 4 clips on each side by using a spudger. And then lift the front corners up and pull towards you to undo them.
    Emil Fisk - 回复
  5. PlayStation 4 Slim 电源更换: 步骤 5 中的图像 1,3 PlayStation 4 Slim 电源更换: 步骤 5 中的图像 2,3 PlayStation 4 Slim 电源更换: 步骤 5 中的图像 3,3
    • 用T8螺丝刀逆时针拧下两颗螺丝(左侧螺丝长31.0mm,右侧螺丝长24.0mm)。
    • 用#1十字螺丝刀逆时针拧下一颗3.0mm长的螺丝。
    UK model seems to be different here. There's no Philips screw where there is on your image.
    MaFt Morley - 回复
    This regards EU models in general, i think. My danish version is the same.
    William Villadsen -
    The screw on the left was 31mm, and the one on my right side was only 19mm.
    Emil Fisk - 回复
  6. PlayStation 4 Slim 电源更换: 步骤 6 中的图像 1,1
    • 移除四颗固定电源的16mm长的十字螺丝。
    Es gibt diese Schrauben bei meiner Ps4 Cuh 2116A nicht und ich bekomme das Teil so nicht raus. Kann mir jmd helfen?
    Julian S. - 回复
    Only 2 Phillips actress here on my UK
    MaFt Morley - 回复
    Only 2 phillips screws on the US one as well.
    Sean Douglas - 回复
    I also only have two screws here in the US.
    Rachel Kelley - 回复
  7. PlayStation 4 Slim 电源更换: 步骤 7 中的图像 1,2 PlayStation 4 Slim 电源更换: 步骤 7 中的图像 2,2
    • 向上移除覆盖在电源顶部的金属片。
    Is this metal sheet required for the unit to power on?
    AlexT - 回复
    I think the metal sheet protects the rest of the console or something from heating too much.
    BloodSpark22 -
    Kann man diesen Metallblech einzeln kaufen? Finde im Internet nichts
    SoN GoKu - 回复
    A quoi sert la tôle métallique qui recouvre le ventilateur et l’alimentation svp
    Ittady92 - 回复
    Que puedo hacer si uno de los tornillos que sujetan esa lamina está barrido y no los puedo quitar?
    Maalem - 回复
  8. PlayStation 4 Slim 电源更换: 步骤 8 中的图像 1,2 PlayStation 4 Slim 电源更换: 步骤 8 中的图像 2,2
    • 顺着固定天线的金属板底部的凸出部分拆下天线。
    What does this mean for part do? This part is not present in my console nor is the space where it's supposed to reside as shown in the picture above.
    The Hondo - 回复
    Me neither, guess they are different models.
    Daniel Henderson -
    There was a longer clip 8mm long on the left side which had to be pulled straight out. However, be careful when pulling out the antenna. My cable was soldered to the metal plate.
    Emil Fisk - 回复
    It is easier to wiggle the cable out from the plastic power supply housing in step 10.
    Emil Fisk - 回复
  9. PlayStation 4 Slim 电源更换: 步骤 9 中的图像 1,2 PlayStation 4 Slim 电源更换: 步骤 9 中的图像 2,2
    • 将PlayStation 4 Slim背面朝上。
    • 用#1十字螺丝刀逆时针拧下一颗4mm长的螺丝。
    Forgot to mention to remove the hard drive.
    The Stuff - 回复
    How do you get it when the screw is stripped
    Lucas Holland - 回复
  10. PlayStation 4 Slim 电源更换: 步骤 10 中的图像 1,3 PlayStation 4 Slim 电源更换: 步骤 10 中的图像 2,3 PlayStation 4 Slim 电源更换: 步骤 10 中的图像 3,3
    • 用撬棒在主机和电源之间撬开一个缝隙。
    • 用手将电源提起并翻转。
  11. PlayStation 4 Slim 电源更换: 步骤 11 中的图像 1,3 PlayStation 4 Slim 电源更换: 步骤 11 中的图像 2,3 PlayStation 4 Slim 电源更换: 步骤 11 中的图像 3,3
    • 用手或镊子将电源上的排线小心地断开。
    • 将电源完全取下。
    Your guide is good but detail. Could be alot better for a start you forgot to mention the screw on the other side that must also be removed to let the power supply out of ps4 slim
    Chicky Boy3 - 回复
    Could you replace a ps4 slim model CUH-211B with a N16-160P1A power supply
    Aiden Thrash - 回复
    Just because I feel like this needs to be stated clearly, “Do no attempt to pull the plug out by the wires!”
    Pull from the plastic, male end of the plug or you’re going to end up have a very bad day.
    Matthew D. H. - 回复
    Literally no way I can do it by the plastic, the only way is wires. Gotta risk it I guess
    Misha FV -
    You are right, pulling the wires is entirely wrong. I used the small rectangular, thin blue plastic to push the cable back from the socket. It was too tight. From my experience of repairing, never pull wires. The consequences of damaging it are not worth it.
    El-Musleh -
结论
请按逆序操作重组设备。
70等其他人完成本指南。
由衷感谢以下译者:
en zh
91%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Hernan Rodriguez
于01/24/18注册
3,642 声望
创作了3篇指南
团队
Cal Poly, Team S19-G4, Livingston Winter 2018 Cal Poly, Team S19-G4, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S19G4
4 名成员
创作了35篇指南
6条评论
Can the N15-160P1A power supply work on a PS4 system that originally came with N17-160P1A?
derasky4u - 回复
My PS4 not turning on
Khai Stering - 回复
This was awesome. Thanks for the assist
Christopher Gorgon - 回复
I need help figuring out what I did to my ps4 and what needs replacement I had the new nba 2k 22 in the disc drive and the game was partly finished downloading so as it was doing that I brought shinobi striker which I previously had to use someone’s account to play it so the game popped up as light so I deleted it the first time and redownloaded it and it still said lite so then I deleted again but this time I double tapped the PlayStation button and it went to Home Screen slowed down then froze so I unplugged it plugged it back up and it wouldn’t turn on
Deontay - 回复
My PS4 runs for 10 minutes and turns off again and again
HITESH MAKWANA - 回复
I really appreciate this help hopefully this doesn't damage my PS4
Karen Loredo - 回复
添加评论
浏览统计数据:
过去 24 小时: 29
过去 7 天: 211
过去 30 天: 1,119
总计 92,755
