跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
PlayStation 4 Slim 底板替换
你所需要的
  1. PlayStation 4 Slim 底板替换, 底盖: 步骤 1 中的图像 1,3 PlayStation 4 Slim 底板替换, 底盖: 步骤 1 中的图像 2,3 PlayStation 4 Slim 底板替换, 底盖: 步骤 1 中的图像 3,3
    • 找到机器后面三个接口旁边的塑料保修警告标签。
    • 用Spudger撬棒揭下保修标签。
    • 移除保修标签并不会意味着您放弃了保修。
    Remove the screw directly to the left of that one in the picture as well. Should be silver.
    Elizabeth Johnson - 回复
    ihr seid so ein scheiß haufen das stimmt über haubt nix
    Toaster 95 - 回复
    einfach alles stimmt nicht
    Toaster 95 - 回复
  2. PlayStation 4 Slim 底板替换: 步骤 2 中的图像 1,2 PlayStation 4 Slim 底板替换: 步骤 2 中的图像 2,2
    • 沿顺时针方向,用T8安全螺丝刀,拧下藏在保修标签后长为5毫米的螺丝。
    Are you SURE that it’s counter-clockwise?
    The Stuff - 回复
    Try T9. Fits better.
    Otter - 回复
    T8 fits like a glove for me
    Daniel Henderson -
    Is there anything else you can use
    randomweeb - 回复
    A small flathead screwdriver will work
    shawng6363 -
    There is a small metal rod in the middle of the screw that isn’t allowing my t8 inside. Any insight on this?
    gavinstoutconner@icloud.com - 回复
    Some T8 bits have a hole in the middle that will allow that rod to go through; some do not. If you have a set of multiple bits, check if there are any others labeled T8 or TR8 with that hole in the middle.
    Nicholas -
    There is a metal thing inside of the screw slot any insite on this?
    Tristan York - 回复
  3. PlayStation 4 Slim 底板替换: 步骤 3 中的图像 1,3 PlayStation 4 Slim 底板替换: 步骤 3 中的图像 2,3 PlayStation 4 Slim 底板替换: 步骤 3 中的图像 3,3
    • 将您的PS4 Slim倒置,使刚刚拧下来的螺丝的那一面面向您。
    • 用手指从两个面向您的边角撬开底盖。
    • 打开它可能需要些微的力,当您将底盖和设备分离时,您将会听到灰常大的清脆的声音。
    • 向后滑动并且抬起底盖就可以移除它了。
    It says to place it upside down, but didn't you do so in the previous step? I've been trying to unscrew the screw with my screwdriver that I got from here and if I had to had the system right side up, I'm afraid I might've stripped the screw from all the force I tried to use to get the screw out that will NOT budge. It didn't even move the slightest after removing the warranty sticker.
    Vidal Santos - 回复
    There is a single clip on the left side about 5cms in, and another clip on the right side equidistant to the one on the other side. Jamming a spudger in there first, and lifting those clips helped, and then I had to slide down to lift a total of 4 clips on each side (each about 4cms apart). Then push the cover away from you, if that makes more sense than “sliding it towards the back corners”, since the back corners are technically facing you.
    Emil Fisk - 回复
    It would be easier if you just lifted the top cover of the PS4.
    Poobler - 回复
    The earlier comment by Emil Fisk is spot-on. I found it impossible to remove the cover without first using a spudger to release the four clips on each side.
    midahed - 回复
    I saw many video and tried it my self, you have to remove the hard disc before removing any cover.
    Bahaa CHEBLI - 回复
结论
要重新组装设备,请按相反的顺序操作。
36等其他人完成本指南。
由衷感谢以下译者:
en zh
87%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Hernan Rodriguez
于01/24/18注册
3,642 声望
创作了3篇指南
团队
Cal Poly, Team S19-G4, Livingston Winter 2018 Cal Poly, Team S19-G4, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S19G4
4 名成员
创作了35篇指南
2条评论
Wo kann man die Bodenplatte kaufen?
Emre Kaman - 回复
添加评论
浏览统计数据:
过去 24 小时: 28
过去 7 天: 134
过去 30 天: 747
总计 47,539
