跳转到主内容
简介
使用这份指南更换PlayStation 4 Slim的主板。
  1. 找到机器后面三个接口旁边的塑料保修警告标签。 用Spudger撬棒揭下保修标签。 移除保修标签并不会意味着您放弃了保修。
    • 找到机器后面三个接口旁边的塑料保修警告标签。
    • 用Spudger撬棒揭下保修标签。
    • 移除保修标签并不会意味着您放弃了保修。
    Remove the screw directly to the left of that one in the picture as well. Should be silver.
    Elizabeth Johnson - 回复
    ihr seid so ein scheiß haufen das stimmt über haubt nix
    Toaster 95 - 回复
    einfach alles stimmt nicht
    Toaster 95 - 回复
  2. 沿顺时针方向,用T8安全螺丝刀,拧下藏在保修标签后长为5毫米的螺丝。 沿顺时针方向,用T8安全螺丝刀,拧下藏在保修标签后长为5毫米的螺丝。
    • 沿顺时针方向,用T8安全螺丝刀,拧下藏在保修标签后长为5毫米的螺丝。
    Are you SURE that it’s counter-clockwise?
    The Stuff - 回复
    Try T9. Fits better.
    Otter - 回复
    T8 fits like a glove for me
    Daniel Henderson -
    Is there anything else you can use
    randomweeb - 回复
    A small flathead screwdriver will work
    shawng6363 -
    There is a small metal rod in the middle of the screw that isn’t allowing my t8 inside. Any insight on this?
    gavinstoutconner@icloud.com - 回复
    Some T8 bits have a hole in the middle that will allow that rod to go through; some do not. If you have a set of multiple bits, check if there are any others labeled T8 or TR8 with that hole in the middle.
    Nicholas -
    There is a metal thing inside of the screw slot any insite on this?
    Tristan York - 回复
  3. 将您的PS4 Slim倒置,使刚刚拧下来的螺丝的那一面面向您。 用手指从两个面向您的边角撬开底盖。 打开它可能需要些微的力,当您将底盖和设备分离时,您将会听到灰常大的清脆的声音。
    • 将您的PS4 Slim倒置,使刚刚拧下来的螺丝的那一面面向您。
    • 用手指从两个面向您的边角撬开底盖。
    • 打开它可能需要些微的力,当您将底盖和设备分离时,您将会听到灰常大的清脆的声音。
    • 向后滑动并且抬起底盖就可以移除它了。
    It says to place it upside down, but didn't you do so in the previous step? I've been trying to unscrew the screw with my screwdriver that I got from here and if I had to had the system right side up, I'm afraid I might've stripped the screw from all the force I tried to use to get the screw out that will NOT budge. It didn't even move the slightest after removing the warranty sticker.
    Vidal Santos - 回复
    There is a single clip on the left side about 5cms in, and another clip on the right side equidistant to the one on the other side. Jamming a spudger in there first, and lifting those clips helped, and then I had to slide down to lift a total of 4 clips on each side (each about 4cms apart). Then push the cover away from you, if that makes more sense than “sliding it towards the back corners”, since the back corners are technically facing you.
    Emil Fisk - 回复
  4. 令PlayStation 4 Slim的右侧,即印有PS标志的一侧朝上放置,并将带有“SONY”和“PS4”字样的一面朝向您。 在朝向你的一侧用手指将顶盖掰开。 打开顶盖需要用不小的力气,而且在打开时卡扣会发出很大的声音。
    • 令PlayStation 4 Slim的右侧,即印有PS标志的一侧朝上放置,并将带有“SONY”和“PS4”字样的一面朝向您。
    • 在朝向你的一侧用手指将顶盖掰开。
    • 打开顶盖需要用不小的力气,而且在打开时卡扣会发出很大的声音。
    • 沿着顶盖向后打开剩余的卡扣并最终移除顶盖。
    Undo 4 clips on each side by using a spudger. And then lift the front corners up and pull towards you to undo them.
    Emil Fisk - 回复
  5. 用T8螺丝刀逆时针拧下两颗螺丝(左侧螺丝长31.0mm,右侧螺丝长24.0mm)。 用#1十字螺丝刀逆时针拧下一颗3.0mm长的螺丝。 用#1十字螺丝刀逆时针拧下一颗3.0mm长的螺丝。
    • 用T8螺丝刀逆时针拧下两颗螺丝(左侧螺丝长31.0mm,右侧螺丝长24.0mm)。
    • 用#1十字螺丝刀逆时针拧下一颗3.0mm长的螺丝。
    UK model seems to be different here. There's no Philips screw where there is on your image.
    MaFt Morley - 回复
    This regards EU models in general, i think. My danish version is the same.
    William Villadsen -
    The screw on the left was 31mm, and the one on my right side was only 19mm.
    Emil Fisk - 回复
  6. 移除四颗固定电源的16mm长的十字螺丝。
    • 移除四颗固定电源的16mm长的十字螺丝。
    Es gibt diese Schrauben bei meiner Ps4 Cuh 2116A nicht und ich bekomme das Teil so nicht raus. Kann mir jmd helfen?
    Julian S. - 回复
    Only 2 Phillips actress here on my UK
    MaFt Morley - 回复
  7. 向上移除覆盖在电源顶部的金属片。 向上移除覆盖在电源顶部的金属片。
    • 向上移除覆盖在电源顶部的金属片。
    Is this metal sheet required for the unit to power on?
    AlexT - 回复
    I think the metal sheet protects the rest of the console or something from heating too much.
    BloodSpark22 -
    Kann man diesen Metallblech einzeln kaufen? Finde im Internet nichts
    SoN GoKu - 回复
    A quoi sert la tôle métallique qui recouvre le ventilateur et l’alimentation svp
    Ittady92 - 回复
  8. 顺着固定天线的金属板底部的凸出部分拆下天线。 顺着固定天线的金属板底部的凸出部分拆下天线。
    • 顺着固定天线的金属板底部的凸出部分拆下天线。
    What does this mean for part do? This part is not present in my console nor is the space where it's supposed to reside as shown in the picture above.
    The Hondo - 回复
    Me neither, guess they are different models.
    Daniel Henderson -
    There was a longer clip 8mm long on the left side which had to be pulled straight out. However, be careful when pulling out the antenna. My cable was soldered to the metal plate.
    Emil Fisk - 回复
    It is easier to wiggle the cable out from the plastic power supply housing in step 10.
    Emil Fisk - 回复
  9. 将PlayStation 4 Slim背面朝上。 用#1十字螺丝刀逆时针拧下一颗4mm长的螺丝。
    • 将PlayStation 4 Slim背面朝上。
    • 用#1十字螺丝刀逆时针拧下一颗4mm长的螺丝。
    Forgot to mention to remove the hard drive.
    The Stuff - 回复
  10. 用撬棒在主机和电源之间撬开一个缝隙。 用手将电源提起并翻转。 用手将电源提起并翻转。
    • 用撬棒在主机和电源之间撬开一个缝隙。
    • 用手将电源提起并翻转。
  11. 用手或镊子将电源上的排线小心地断开。 将电源完全取下。 将电源完全取下。
    • 用手或镊子将电源上的排线小心地断开。
    • 将电源完全取下。
    Your guide is good but detail. Could be alot better for a start you forgot to mention the screw on the other side that must also be removed to let the power supply out of ps4 slim
    Chicky Boy3 - 回复
    Could you replace a ps4 slim model CUH-211B with a N16-160P1A power supply
    Aiden Thrash - 回复
    Just because I feel like this needs to be stated clearly, “Do no attempt to pull the plug out by the wires!”
    Pull from the plastic, male end of the plug or you’re going to end up have a very bad day.
    Matthew D. H. - 回复
    Literally no way I can do it by the plastic, the only way is wires. Gotta risk it I guess
    Misha FV -
  12. 用T8螺丝刀逆时针拧下一颗31.0mm长的螺丝。 用T8螺丝刀逆时针拧下一颗31.0mm长的螺丝。
    • 用T8螺丝刀逆时针拧下一颗31.0mm长的螺丝。
  13. 找到连接着主板底部的两条线缆。 用镊子或手指小心地向上提起线缆直到断开连接。
    • 找到连接着主板底部的两条线缆。
    • 用镊子或手指小心地向上提起线缆直到断开连接。
    Doesn't exist in my
    Daniel Henderson - 回复
  14. 令主机背面朝上。 用#1十字螺丝刀逆时针卸下14颗4mm长的黑色螺丝。
    • 令主机背面朝上。
    • 用#1十字螺丝刀逆时针卸下14颗4mm长的黑色螺丝。
    • 用#1十字螺丝刀逆时针卸下8颗6mm长的银色螺丝。
    • 用#1十字螺丝刀逆时针卸下4颗3mm长的银色螺丝。
    - There are 14x 4.0mm black screws, but the step only shows 13 of them circled in red. One of the 11 orange circles (near front of unit) is actually the 14th black screw. Photo: http://i.imgur.com/7G64egd.png
    - As for the 6.0mm silver screws, there are only 8x of those. The two silver screws behind the IO ports on the back are 3.0mm fine-threaded screws. Photo: http://i.imgur.com/cQD6KQu.png
    - Source: Have a PS4 Slim (CUH-2015A) right in front of me, doing this exact job. Hope this helps someone else down the road.
    lane anderson - 回复
  15. 用#1十字螺丝刀逆时针卸下主机侧面两颗5.0mm长的螺丝。 用#1十字螺丝刀逆时针卸下主机侧面两颗5.0mm长的螺丝。
    • 用#1十字螺丝刀逆时针卸下主机侧面两颗5.0mm长的螺丝。
    These are 3.0mm screws, not 5.0mm. This step could probably be condensed into the previous step.
    lane anderson - 回复
  16. 找到连接着主板一角的白色线缆。 用手或镊子小心地向上提起线缆直到断开线缆的连接。 将胶带固定的线缆完全移出。
    • 找到连接着主板一角的白色线缆。
    • 用手或镊子小心地向上提起线缆直到断开线缆的连接。
    • 将胶带固定的线缆完全移出。
  17. 用手指将排线上带有蓝色标志的部分拔出。 在移除排线前,先用手指翻开黑色的固定卡扣。 用手指握住线缆并将线缆拽下。
    • 用手指将排线上带有蓝色标志的部分拔出。
    • 在移除排线前,先用手指翻开黑色的固定卡扣。
    • 用手指握住线缆并将线缆拽下。
  18. 握住金属盖板的两侧,向上移除并妥善保存。 在提起盖板前,你可能需要左右晃动几下以松开盖板。
    • 握住金属盖板的两侧,向上移除并妥善保存。
    • 在提起盖板前,你可能需要左右晃动几下以松开盖板。
    • 在进行这个步骤时,注意不要弄掉主板上的任何黑色导热垫。
    This step would benefit from showing a picture of the black pads in question. Pic: http://i.imgur.com/zQnehtA.png
    lane anderson - 回复
  19. 用#1十字螺丝刀逆时针拧下两颗10.0mm长的螺丝(一颗是银色,一颗是黑色)。 用手指向上提起并移除小金属片。 用手指向上提起并移除小金属片。
    • 用#1十字螺丝刀逆时针拧下两颗10.0mm长的螺丝(一颗是银色,一颗是黑色)。
    • 用手指向上提起并移除小金属片。
    Why is one silver and one black? I keep thinking they are different and try to keep track of where they go.
    Reed Deemer - 回复
    What's the name is the part with the two metal screws that is being taken off
    Devon Higgins - 回复
  20. 用镊子夹紧并拽开线缆。 这一步需要比较大的力气,但请注意不要弄断线缆。 这一步需要比较大的力气,但请注意不要弄断线缆。
    • 用镊子夹紧并拽开线缆。
    • 这一步需要比较大的力气,但请注意不要弄断线缆。
    Do not attempt to disconnect the plug by pulling on the wires! If you rip out the wires, you’re gonna have a very bad day. Wiggle the plug using the plastic on the male end of the connector while pulling out.
    Matthew D. H. - 回复
    que pasa si se desolda esa parte como puedo volver a soldarlo o cuanto se cobra por solo soldar
    TheKiller Xtreme1 - 回复
  21. 握住主板的一边或两边并将主板向上提起。 你也许需要晃动几下主板才可以将其移除。
    • 握住主板的一边或两边并将主板向上提起。
    • 你也许需要晃动几下主板才可以将其移除。
结论
要重新组装你的设备,请按照指南的相反顺序操作。
49等其他人完成本指南。
特别感谢这些译者︰
en zh
100%
mallow正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Harry Koos
于2018年01月24日注册
3,585 信誉积分
创作了2篇指南
团队
Cal Poly, Team S19-G4, Livingston Winter 2018 Cal Poly, Team S19-G4, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S19G4
4 名成员
创作了35篇指南
9条评论
Hi Harry
I think this guide is fantastic. My PS4 slim is not coming on. It’s not the HDMI display port or anything of the sort. It powers on, you hear the beep and the blue power light stays on. That’s all. Nothing after this… no signal to the TV, cannot reinitialise, nothing. I’ve checked online to see if I can diagnose it. Based on the few signs I’ve seen I think the board is gone. So am looking to replace that hence I came across your guide. Is there a way you know to be certain my board is faulty. Thanks
Jx Corp - 回复
I have a PS4 slim issue…. when connected to power it doesn't show it’s on and no light displays….. I would say the board is faulty and how do I work on such problem.
michael quartey - 回复
do you need to change the optical drive as well?
Hafiz Adam - 回复
my ps4 slim power supply ok no power motherboard
Naeem Tyagi - 回复
Very good repair guide, but it’s incomplete. The first step is remove the HDD (hard disk drive).
Yeong - 回复
We don't need thermal paste, or to replace the optical drive?
Thembiswa Dlamini - 回复
My PS4 Slim Output has a-lot of static interference and idk y
skydimondlox - 回复
Thanks for the amazing guide. I need to replace my motherboard. How do i know what model replacement should i be looking for?
Radoslav Trahanov - 回复
Good evening I wonder if A ps4 islim matherboard SAE-002 if you give to exchange for A SAE-001 thank you
scooott519 - 回复
添加评论
浏览统计数据:
过去的24小时: 62
过去的7天: 377
过去的30天: 1,771
总计 64,191
