简介
你换电源组件的原因应该是你的设备无法正常运行吧。开始你的置换工作前,请确认你有所需的工具、自由时间和宽敞整洁的区域。不要相信大力出奇迹,一切以轻柔为主,因为你可能会很轻易的损坏他们。请花些时间来阅读此指南。
你所需要的
向旁边移开光驱可以看见一颗长度为8.8毫米的银色螺丝
使用十字螺丝刀拧下它
be careful, the fiber-optic cables come out easily and are a pain to put back in
拔出白色的插头
卸下电源组件。(竖直向上提起电源,可能需要一点点力气)
The left side of the PSU sits on two long metal prongs so you may need to pull a little to get it lose but you should be able to pull the whole unit in an upward motion
倒序看此指南便是组装回你的PS3
倒序看此指南便是组装回你的PS3
22等其他人完成本指南。
由衷感谢以下译者:
100%
James HJH正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
9条评论
Perfect how to guide. Fixed my PS3 easily. Thanks
Great guide. However, still no power on PS3. Any suggestions as to what else may be the problem?
Peter Maher, I am in the same boat. I have no idea what the problem is. Red light in standby, but as soon as I try to power on, nothing. Same as before I did this power supply replacement. Obviously, something else is the problem. Anyone who has some insight into this please help!
Did you guys get word on the red light with no power on fix mine has the same issue.
i have the same problem as Peter Maher, the red light is in standby neither turning green on pressing nor it sounds beep on long press. dont know whats wrong. anyone has any solution to this?
thanks for guide - had a blown power unit and this was a useful guide to getting at it so it could be replaced. I couldn’t see a guide for taking the power unit apart so with nothing to lose I opened that up to see what was going on, and could see the charred remains of what I guess was a capacitor. New power unit in there now and working great. thanks
Phil March - 回复
comment fait si sa ps3 ne démarré pas?
Just wanted to add: the HDD bay cover isn't on the right all the time, it varies with each unit. The side without the rubber PS logo is the bay cover.
Yash - 回复
I just wanted to add that the above is not correct either
My PS3 Super Slim Mdel No. CECH-4004A has the removable PS logo rubber seal on the left side while the HDD is housed behind the right side (with no rubber PS logo seal)
Eoin - 回复
