跳转到主内容
PlayStation 3 Slim Top Cover Replacement
你所需要的
  1. PlayStation 3 Slim Top Cover Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Top Cover Replacement: 步骤 2 中的图像 1,2 PlayStation 3 Slim Top Cover Replacement: 步骤 2 中的图像 2,2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Top Cover Replacement: 步骤 3 中的图像 1,1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Top Cover Replacement: 步骤 4 中的图像 1,1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Top Cover Replacement: 步骤 5 中的图像 1,2 PlayStation 3 Slim Top Cover Replacement: 步骤 5 中的图像 2,2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
结论
92等其他人完成本指南。
2条评论
No good mine a Sony.
james register - 回复
Thank you this helped me so much!!!!
Megan Davis - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 90
过去 30 天: 325
总计 73,298
