跳转到主内容
PlayStation 3 Slim顶盖更换
你所需要的
  1. PlayStation 3 Slim顶盖更换, 顶盖: 步骤 1 中的图像 1,1
    • 将PS3翻转过来,然后放在其背面。
    • 小心地将保修标签从下壳上剥下来,露出隐藏的螺丝盖。
    • 为避免激活可能会出现的VOID,请仔细加热标签以清除并干净地更换它。
    Don’t even need to bother with the sticker anymore since SONY does not care what you do with them anymore.
    Travis Wheeler - 回复
  2. PlayStation 3 Slim顶盖更换: 步骤 2 中的图像 1,2 PlayStation 3 Slim顶盖更换: 步骤 2 中的图像 2,2
    • 用金属撬棒的平端撬起下壳体边缘的七个螺丝盖。
  3. PlayStation 3 Slim顶盖更换: 步骤 3 中的图像 1,1
    • 卸下将顶盖固定到下壳的7颗37毫米十字螺丝。
  4. PlayStation 3 Slim顶盖更换: 步骤 4 中的图像 1,1
    • 卸下蓝光驱动器开口下方的四颗13.3毫米T8安全梅花螺钉。 (某些型号可能只有三个螺丝)
    Its 4 screws beneath the blu-ray
    Manuel - 回复
    Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening.
    Daniel Tlapa - 回复
    Can we edit this to say 4 screws?
    revanantwraith - 回复
    I made the change from three to four screws, but you're able to edit the guides as well. If you want to edit something, you can click the Edit link on the right side of any guide step, or the Edit link at the top right of the page (sandwiched in-between View and History).
    Taylor Arnicar -
    Do you guys have a guide for the PS3 Slim Model 3001A. The fan is different than this model.
    emknight04 - 回复
    3001a is basically same motherboard but cheaper plastic bd drive other than that its exactly the same until you get to the new slim line
    Robert -
    Anyone know an online retailer with a competitive price for the replacement fan?
    Jared - 回复
    My PS3 had only three Torx screws. Having four in the diagram was initially confusing. Obviously they made a mid-stream change at some point (mine is several years old now).
    corygbooker - 回复
    I've accidentally removed the ribbon cable from the blu-Ray drive and can not seem to figure out how to reconnect it. Can anyone help?
    OneIfByLand - 回复
    Take the top off the drive, connect the ribbon to the motherboard then replace the drive sliding the ribbon through the slot on the bottom of the drive and reconnect to the laser.
    KcXbox Repair -
    pls help i have to tear down my ps3 slim but the 4 srews are very hard to take it out because there is a needle in the middle pls hep
    vbrabandt - 回复
    If the screw has a pin in the center, that means it is a security Torx meant to prevent tampering. To remove this screw, follow the guide I have linked below...
    http://www.instructables.com/id/Removing...
    Telpack - 回复
    How do u buy the screw driver for these screws
    mistergalacta hoggy - 回复
    Online at the usual suspects?
    Or some hobby stores or places that sell tools will sometimes carry these.
    revanantwraith -
    Anyone else's screws for this step need the T7 bit instead of T8?
    Michael J Cotton - 回复
    What is the name of this screwdriver
    Mohammad Shawa - 回复
  5. PlayStation 3 Slim顶盖更换: 步骤 5 中的图像 1,2 PlayStation 3 Slim顶盖更换: 步骤 5 中的图像 2,2
    • 从顶盖的后边缘提起顶盖,然后将其向PS3的前面旋转。
    • 将顶盖提离PS3。
    I just want to open the top cover to clean the fan. Do I need to unscrew the four security screws?
    Aryan - 回复
结论
要重新组装设备,请按照逆序进行操作。
92等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
2条评论
No good mine a Sony.
james register - 回复
Thank you this helped me so much!!!!
Megan Davis - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 63
过去 30 天: 320
总计 73,306
