简介
图解索尼新出的薄版PS3
你所需要的
这个步骤还没有翻译 帮忙翻译一下
It's here! We got our dirty hands on a PS3 Slim a full day before it was set to arrive in the mail!
The box, just like the unit, is, well, slimmer.
Our free online editor makes it super-easy to publish step-by-step teardowns.
We host everything for free, and make it easy for you to have high-resolution photos, professional layout, and full-screen slideshows like ours!
这个步骤还没有翻译 帮忙翻译一下
On the front left, we have two USB ports, a hard drive indicator light, and a Wi-Fi indicator light.
Front right yields a slot-loading Blu-ray drive, power button, and eject button.
The back has a LAN connection, HDMI port, digital audio-out, multi-connector (RCA or component video) and a new type of power plug.
Owners of the current-gen PS3s will notice an absence of the rear manual power switch. All your powering needs are now served by the front power button.
这个步骤还没有翻译 帮忙翻译一下
Remove the three (or on some models, four) TR8 security Torx screws on the underside of the PS3 slim.
What's that, you say? Security screws? Yes, that's right. These screws have a pin in the center of them that prevents an ordinary Torx screwdriver from working. These screwdrivers are widely available, just not quite as easy to come by as a normal Torx.
Sony did this to prevent people like us from taking it apart.
This seems a little spiteful-- hardware hacking is a fine American tradition. No worries, we'll make sure it's easy for you to get these screwdrivers.
这个步骤还没有翻译 帮忙翻译一下
Closeup of the massive fan and controller antennas.
This is a brushless DC motor, which is fairly standard for fans in devices like this. Brushless motors are quieter than more traditional fans, but require fine computer control to function. It is not a maglev fan like Apple is known to use, however.
The Bluetooth and WLAN antennas, intentionally three-dimensional in design, are attached to the lower case with Phillips screws.
这个步骤还没有翻译 帮忙翻译一下
This is the largest fan we've come across in a consumer electronics device of this size.
Sony is really taking cooling quite seriously.
The ~95 mm diameter 17 blade impeller was definitely designed with quiet in mind. It is extremely stiff and presumably made of ABS plastic.
这个步骤还没有翻译 帮忙翻译一下
More connectors and screws to unplug/unscrew.
The design aesthetic of this machine is quite a bit more bare-bones-functional than Apple's, but is still beautiful in its own way.
Several components, including the AC power inlet, are simply held to the unit by the pressure of the screws connecting the top and bottom cases.
这个步骤还没有翻译 帮忙翻译一下
That's it for the disassembly, but we'll continue to post board photos and analysis as the information pours in.
The logic board. Sony's going green on the inside, to reflect their commitment to the environment.
We've never seen cool snowflake-like patterns in the thermal paste after we removed a heat sink before. This may indicate that the thermal paste was overapplied or that it was not distributed evenly.
If you look closely at the thermal paste, you'll see it is a fractal!
这个步骤还没有翻译 帮忙翻译一下
Multiple manufacturers, multiple functions. The first picture shows two of the four NEC/TOKIN 0e108 capacitors.
NEC/TOKIN Corporation creates "next-generation, value-added devices that integrate." Whatever that means.
High Speed Decoupling Device Proadlizer PF/A SeriesProadlizer PF/A Series.
Dual Elpida 512Mbit RAM chips (there are four total on the board).
The third picture shows, from left to right:
Marvell Ethernet controller
Panasonic HDMI controller
Sony AV multi-out controller
这个步骤还没有翻译 帮忙翻译一下
But wait -- there's more!
Clock generators from left to right:
Clock generator (1): ICS 9249AGLF
Clock generator (2): ICS 1493DG
Samsung K8Q2815UQB-PI4B
SW2-301 0920KMOOT
Sony CXD9963G8
由衷感谢以下译者:
6%
wewewawa正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
18条评论
Just a question.. Where's the wifi card? And can I update it to the new wifi ac? Id love to have gigabit speeds on my Sony.
this was extremely helpful, I had to replace the 450aaa, shop cost $125.00, after finding the part on ebay (w/ebay credit) and doing it myself...26 cents!
jedimasta1 - 回复
Hi, I am about to order a PS3 power Ribbon for mine because i have an issue that just started. When you turn it on, it cuts off and you have to keep turning it on over and over until it finally stays on. This is now all the time from being powered off and back on. It literally just started a few days ago. So after some research it looks like it could be the power/eject ribbon. My model number is CECH-2001A. In which picture is the ribbon that needs to be replaced? Is it 18? Thanks!
