跳转到主内容
PlayStation 3 Slim Power Supply Replacement
你所需要的
  1. PlayStation 3 Slim Power Supply Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Power Supply Replacement: 步骤 2 中的图像 1,2 PlayStation 3 Slim Power Supply Replacement: 步骤 2 中的图像 2,2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Power Supply Replacement: 步骤 3 中的图像 1,1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Power Supply Replacement: 步骤 4 中的图像 1,1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Power Supply Replacement: 步骤 5 中的图像 1,2 PlayStation 3 Slim Power Supply Replacement: 步骤 5 中的图像 2,2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim Power Supply Replacement, Power Supply: 步骤 6 中的图像 1,2 PlayStation 3 Slim Power Supply Replacement, Power Supply: 步骤 6 中的图像 2,2
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  7. PlayStation 3 Slim Power Supply Replacement: 步骤 7 中的图像 1,1
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  8. PlayStation 3 Slim Power Supply Replacement: 步骤 8 中的图像 1,1
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  9. PlayStation 3 Slim Power Supply Replacement: 步骤 9 中的图像 1,1
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  10. PlayStation 3 Slim Power Supply Replacement: 步骤 10 中的图像 1,2 PlayStation 3 Slim Power Supply Replacement: 步骤 10 中的图像 2,2
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
结论
52等其他人完成本指南。
11条评论
Hello, my question is I have an american ps3 which works on 110 volts and I'm in europe where they use 220volts so if I plug my ps3 without any converters will it burn or will it wor? Because I have a laptop and it works fine will my ps3 work like that aswell?
Remigijus Untulis - 回复
Perhaps, you should check the model of your PS3 and verify online. I have the CECH-2501B model (110v) but I use it in Nigeria (220v).
N3RVE -
Need help with console or trouble shooting the problem I am in the repair and purchased used or damage consoles even get it In way I can be able to talk to people who is looking for trouble shooting on phone or email or u to choose. But any console or device I am interested in buying it so I have it on hand I have seen people pay way more 4 the part. Wene it is sometimes. New or used Console r cheaper to get the whole different devices then part for the console
Jason Ellis -
More to my comment I can be able to talk or text or email. SO you can do it yourself and it's not to bad to diy and your up to run the console after u fixed it. Do I you self. (Diy) even if people walk through it step 4 step.
Jason Ellis -
I have a PS3 Slim (CECH-3004B)
Can I install any PSU what is made for PS3 slim?
Or I should make a research what kind of PSU can be installed into my model (CECH-3004B) ?
Thank you for your help in advance ^^
Jani - 回复
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 134
过去 30 天: 631
总计 84,930
