简介
Use this guide to replace your PlayStation 3 Slim's CR 2032 coin-cell PRAM battery.
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
Can we edit this to say 4 screws?
I made the change from three to four screws, but you're able to edit the guides as well. If you want to edit something, you can click the Edit link on the right side of any guide step, or the Edit link at the top right of the page (sandwiched in-between View and History).
Do you guys have a guide for the PS3 Slim Model 3001A. The fan is different than this model.
emknight04 - 回复
3001a is basically same motherboard but cheaper plastic bd drive other than that its exactly the same until you get to the new slim line
Robert -
My PS3 had only three Torx screws. Having four in the diagram was initially confusing. Obviously they made a mid-stream change at some point (mine is several years old now).
I've accidentally removed the ribbon cable from the blu-Ray drive and can not seem to figure out how to reconnect it. Can anyone help?
Take the top off the drive, connect the ribbon to the motherboard then replace the drive sliding the ribbon through the slot on the bottom of the drive and reconnect to the laser.
pls help i have to tear down my ps3 slim but the 4 srews are very hard to take it out because there is a needle in the middle pls hep
If the screw has a pin in the center, that means it is a security Torx meant to prevent tampering. To remove this screw, follow the guide I have linked below...
How do u buy the screw driver for these screws
Online at the usual suspects?
Or some hobby stores or places that sell tools will sometimes carry these.
Anyone else's screws for this step need the T7 bit instead of T8?
Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
Question: if a screw doesn't come out, what do you recommend, without potentially damaging the system, inside and out?
kramiz2488 - 回复
It seems these can be quite tight, but they did come loose with someextra force in my case. They did that thing where it makes cracking sounds, but nothing really breaks. They're just really tight in there. - I just wouldn't recommend taking these out too often.
The screwdrivers on the guide didn't work mine just don't come out any tips model is slim CECH 2001A
Step 8
These screws work as a ground pass through between the motherboard shields and the power supply. My cousin took his PS3 to a repair shop to replace the power supply, they didn’t put the screws back in after that and the PS was shutting down suddenly (no light green or red), put a couple of new screws and it’s being working fine since
Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
Remove the power supply from the PS3, minding any cables that may get caught.
It seems it kind of ends for me here. I can only lift the left side about an inch and then the right side stays down like it’s stuck to something underneath. It feels like I’m bending something. Could something have melted underneath?… It's really stuck, I can't get it to come loose. And I can't see much shining a light into it either. - Any tips?…
Did you undo the screws?
I had the same issue but was able to get it off. The right side (as per the above picture) has two long column like sections that actually goes into the machine. Took me a bit of wiggling and some brute force.
Ivan Amaro - 回复
Um, I translated the guide from French to English and the name of the guide was “Food” and the description said “This guide shows you how to replace your diet” The translation is incorrect just to let you know!
Hi! Thanks for you attention! But no worries, the French word “alimentation” means power, food or diet depending the context.
Alright, thanks!
Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
Remove the Blu-ray drive from the PS3.
my cd drive has 3 cables, two by the fan, one right under, i believe i damaged the one on the bottom because it is very difficult to put back in hence the repair. But the photos here dont show the 3 cables, not sure if you have one for this model?
I followed the steps and I successfully removed my disc drive the guide was helpful but I had issues and the ribbon cables on my replacement disc drive were too short after a soddering attempt failed I now need to rebut a disc drive can someone direct me to a proper replacement with the correct size I need it's a ps3 slim 120G please help
Completely different drive in my slim. 3 ribbon cables on the back that pull straight up out of their connectors. And one wide ribbon hidden underneath and almost impossible to get to. After disconnecting the 3 visible cables lift the back of the drive about 3/4" and use a plastic spudger to release the clip on the cable before lifting off the drive. Reinstalling is a nightmare. The cable has a black line to indicate how far to insert into the connector. Get it in there somehow then use the spudger to push the clip down. If it's not level release it and try again and again and again until you get it right. Sony must use some awfully small fingers when they build these ;-)
I had the same issue with the ribon feeding beneath the blu ray player. This video provided a much better solution. It requires dissassembling the blu ray: https://youtu.be/Upy2bTev3M0
My disk drive needs to be replaced. Your step by step is straight forward and are very helpful. At the end you mentioned “If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive”.
Which circuit board? Can your please add a picture of the circuit board you are referring to?
@hh168 There’s now a link in the text of that step, which will take you to a video with detailed instructions for swapping the board.
First I replaced the drive and it would load a disc and see that it was either a game and which game or a BluRay or DVD and which, but I got error codes when trying to play them.
The codes seemed to be tamper coding, and swapping the board seemed to be a good idea.
It went smoothly, but now discs will not feed into the drive.
Please help.
While holding the plastic retainer down against the board, use the tip of a spudger to pry the PRAM battery out of its housing.
I didn't force the battery out here at all but when putting out back in it feels so loose. What could be the problem
Wrong type of battery, perhaps? A 2016 battery will be the same diameter as the (correct) 2032 battery, but thinner.
My PS3 did not have the convenient cutout as in the picture of step 17. Instead there was a grill through which I could see the battery. I had to figure out how to remove that plate completely.
You have to disconnect the fan power, and the Bluetooth and WiFi cables from the board, then open around 5 marked Philips screws. Unscrew 2 smaller screws holding the hard drive assembly to the case.
Then you have to lift the motherboard from the case by pulling at the other end of the board from the fan. Underneath there are another set of marked Philips screws. Two sets of larger Philips screws hold down the brackets for I guess the CPU and GPU. Finally you can get at the coin cell and replace it.
Absolutely ridiculous design, probably meant to make the consumer run to a Sony service center. Unfortunately I did not take pictures of the process and hopefully the battery will last another 5 years or so before I have to do this exercise again.
One more thing. The Blu-Ray drive in my unit has different cabling. One of the cables is underneath the drive and might easily get damaged. Replacing it back in the socket also requires care and time.
Echoing Sanjay Martha's comment exactly. There are 3 cables on the back of the blue ray and a surprise one on the underside which is very fiddly to get back in. Needs the hands of a child to reach in and seat it. Lol. I guess the reason the battery isn't in a neatly accessible slot on the outside case is so you can buy a new PlayStation instead. Shocking design to have to dismantle the whole thing almost entirely just to change a battery. So risky. The date appears to now save but I need to test the blue ray and the hard drive are still functioning. Different battery set up as well. Not a battery in an insulator with cables. Join a standard coin battery into the housing.
20等其他人完成本指南。
9条评论
ATTENTION: This guide is not valid for PS3 slim CECH-3004B!
from the number 11 you notice that your ps3 is different.
The CECH-3004B version does not give direct access to the 2032 battery.
You must also disassemble the motherboard from the grid (and all the pieces that obstruct this operation)
It is possible but it is more difficult
I found this to be the case too. Did you end up replacing the battery? If so, how did you do it?
Same for CECH-2501A, I got the blu-ray drive out and was greeted by a battery covered by the metal shielding. Have to go deeper...
It is kind of hard to tell by the photo alone: The plus (flat) side of the battery must face up when you insert it.
kuhnbn hob - 回复
hey i need serious help i opened my super slim to replace the battery and could not figure how to get it out thought off lifting the socket might allow me to replace the battey much to my horror now socket is torn from the motherborad my console is stuck in black screen and a day before i tried to update from safe mode still a black screen now if i turn on the console i know its waiting for to confirm update iniatlization can i update the console without cmos battery or shomhow cancel it and be able to boot into recovery again
Hello, I need help haha I wanted to remove the battery and effectively broke the plastic and released the solder that goes from the battery to the motherboard, can I solder it again?
What if you have the Super Slim Version of the Ps3, can i still do that on there?
Watch out if you have a later revision of the slim ( 3000 series, the ones that don’t have a light above the disc eject button). The Blu-Ray drive ribbon cable in step 13 is located underneath the drive on this revision, which can be tricky to remove and re-insert. You also have to disassemble the console down to the bare motherboard to get at the PRAM battery, which means removing the cooler and having to re-paste the CPU and GPU when putting it back together (which you probably should do anyway while you have it open.
Unfortunately, my version of PS3 slim is different. Cabeling of Blu-ray drive is different and the worst thing is that battery is covered by metal so if you want to exchange it you have to dismantle ps3 completely. So stupid design.
Don’t even need to bother with the sticker anymore since SONY does not care what you do with them anymore.
Travis Wheeler - 回复
