跳转到主内容
PlayStation 3 Slim Laser Unit (Laser and Mechanism) Replacement
你所需要的
视频概述
  1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): 步骤 1 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): 步骤 1 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): 步骤 1 中的图像 3,3
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 2 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 2 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 2 中的图像 3,3
    • Remove Power Supply.
  3. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 3 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 3 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 3 中的图像 3,3
    • Separate cables, unscrew the screw and remove the Blu Ray drive.
  4. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 4 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 4 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 4 中的图像 3,3
    • Disassemble the upper metal shield.
  5. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 5 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 5 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 5 中的图像 3,3
    • Remove the two very small phillips screws in each lower corner referenced by the red circles.
  6. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 6 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 6 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 6 中的图像 3,3
    • Be careful with flex cables.
  7. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 7 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 7 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 7 中的图像 3,3
    • Now you can remove the Laser Deck.
  8. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 8 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 8 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 8 中的图像 3,3
    • Transfer two flex cables and 2x rubbers.
  9. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 9 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 9 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 9 中的图像 3,3
    • You can test the console before full assembling.
结论
16等其他人完成本指南。
ZFix
于12/09/13注册
187,961 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
311 名成员
创作了1,196篇指南
一条评论
Do you know what the part number is for the deck? I don’t want to buy the wrong one. Thanks.
Edmond Charrette - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 58
过去 30 天: 298
总计 25,053
