跳转到主内容
PlayStation 3 Slim Laser Unit (Laser and Mechanism) Replacement
你所需要的
视频概述
  1. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): 步骤 1 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): 步骤 1 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement, Laser Unit (Laser and Mechanism): 步骤 1 中的图像 3,3
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 2 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 2 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 2 中的图像 3,3
    • To remove the power supply, first disconnect the two cables, then the 2 Phillips screws. Then lift it upwards.
  3. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 3 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 3 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 3 中的图像 3,3
    • Separate cables, unscrew the screw and remove the Blu Ray drive.
    • Depending on the model of your PS3 Slim, the number of cables to be removed may vary between 2 and 4. If your model has more than one ribbon cable, remove the drive very carefully, as a fourth ribbon cable may be hidden underneath.
  4. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 4 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 4 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 4 中的图像 3,3
    • Disassemble the upper metal shield by first unscrewing the 3 Phillips screws.
    • On the 2-cables model, you'll need to unscrew an additional 2 small Phillips screws, located on the underside of the drive. While you're at it, unscrew the 2 other Phillips screws at the bottom of the shield. (Their presence does not prevent removal of the upper metal shield, but removing them will be useful later).
  5. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 5 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 5 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 5 中的图像 3,3
    • For the 2-cables model, remove the two very small phillips screws in each lower corner referenced by the red circles.
    • For the 4-cables model, remove the small Phillips screw in the bottom left corner referenced by the red circle.
  6. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 6 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 6 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 6 中的图像 3,3
    • Carefully remove the plastic shell, paying attention to the cable that runs through it for the 4-cables model.
  7. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 7 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 7 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 7 中的图像 3,3
    • Remove the 4 Phillips screws at each corner of the laser mechanism.
    • Then remove the mechanism.
  8. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 8 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 8 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 8 中的图像 3,3
    • If necessary, transfer parts and screws from the old mechanism to the new one.
  9. PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 9 中的图像 1,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 9 中的图像 2,3 PlayStation 3 Slim  Laser Unit (Laser and Mechanism) Replacement: 步骤 9 中的图像 3,3
    • You can test the console before full assembling.
    • To do this, reassemble the blu-ray drive, reconnect its cables, and reconnect the power supply.
结论
16等其他人完成本指南。
ZFix
于12/09/13注册
191,182 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,521篇指南
一条评论
Do you know what the part number is for the deck? I don’t want to buy the wrong one. Thanks.
Edmond Charrette - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 52
过去 30 天: 277
总计 28,698
