跳转到主内容
PlayStation 3 Rear Cover Replacement
你所需要的
  1. PlayStation 3 Rear Cover Replacement, Smart Plate: 步骤 1 中的图像 1,2 PlayStation 3 Rear Cover Replacement, Smart Plate: 步骤 1 中的图像 2,2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Rear Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Rear Cover Replacement: 步骤 3 中的图像 1,3 PlayStation 3 Rear Cover Replacement: 步骤 3 中的图像 2,3 PlayStation 3 Rear Cover Replacement: 步骤 3 中的图像 3,3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Rear Cover Replacement: 步骤 4 中的图像 1,1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Rear Cover Replacement, Top Cover: 步骤 5 中的图像 1,1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Rear Cover Replacement: 步骤 6 中的图像 1,1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Rear Cover Replacement, Blu-ray Disc Drive: 步骤 7 中的图像 1,1
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
  8. PlayStation 3 Rear Cover Replacement: 步骤 8 中的图像 1,1
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  9. PlayStation 3 Rear Cover Replacement: 步骤 9 中的图像 1,3 PlayStation 3 Rear Cover Replacement: 步骤 9 中的图像 2,3 PlayStation 3 Rear Cover Replacement: 步骤 9 中的图像 3,3
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
  10. PlayStation 3 Rear Cover Replacement, Motherboard Assembly: 步骤 10 中的图像 1,1
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  11. PlayStation 3 Rear Cover Replacement: 步骤 11 中的图像 1,2 PlayStation 3 Rear Cover Replacement: 步骤 11 中的图像 2,2
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  12. PlayStation 3 Rear Cover Replacement: 步骤 12 中的图像 1,1
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
  13. PlayStation 3 Rear Cover Replacement: 步骤 13 中的图像 1,1
    • Remove the control board bracket.
  14. PlayStation 3 Rear Cover Replacement: 步骤 14 中的图像 1,2 PlayStation 3 Rear Cover Replacement: 步骤 14 中的图像 2,2
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  15. PlayStation 3 Rear Cover Replacement: 步骤 15 中的图像 1,1
    • Lift the motherboard assembly out of the lower case.
  16. PlayStation 3 Rear Cover Replacement, AC Inlet: 步骤 16 中的图像 1,1
    • Remove the 7.7 mm Phillips screw securing the ground strap to the chassis.
  17. PlayStation 3 Rear Cover Replacement: 步骤 17 中的图像 1,2 PlayStation 3 Rear Cover Replacement: 步骤 17 中的图像 2,2
    • Pull the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
    • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
  18. PlayStation 3 Rear Cover Replacement: 步骤 18 中的图像 1,1
    • Pull the AC inlet out from the bottom of the rear cover, minding any of its cables that may get caught.
  19. PlayStation 3 Rear Cover Replacement, Rear Cover: 步骤 19 中的图像 1,2 PlayStation 3 Rear Cover Replacement, Rear Cover: 步骤 19 中的图像 2,2
    • While lightly pulling the rear cover away from the logic board assembly, use the flat end of a spudger to release the clips along the top and bottom edges of the rear cover.
  20. PlayStation 3 Rear Cover Replacement: 步骤 20 中的图像 1,1
    • Remove the rear cover from the logic board assembly.
结论
9等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 32
总计 12,274
