跳转到主内容
加入维修社区 - 创建账户
PlayStation 3 Control Board Replacement
你所需要的
  1. PlayStation 3 Control Board Replacement, Smart Plate: 步骤 1 中的图像 1,2 PlayStation 3 Control Board Replacement, Smart Plate: 步骤 1 中的图像 2,2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Control Board Replacement: 步骤 2 中的图像 1,1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Control Board Replacement: 步骤 3 中的图像 1,3 PlayStation 3 Control Board Replacement: 步骤 3 中的图像 2,3 PlayStation 3 Control Board Replacement: 步骤 3 中的图像 3,3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Control Board Replacement: 步骤 4 中的图像 1,1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Control Board Replacement, Top Cover: 步骤 5 中的图像 1,1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Control Board Replacement: 步骤 6 中的图像 1,1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Control Board Replacement, Control Board: 步骤 7 中的图像 1,2 PlayStation 3 Control Board Replacement, Control Board: 步骤 7 中的图像 2,2
    • Use your fingernail to flip up the retaining flap on the control board ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the control board ribbon cable out of its socket.
  8. PlayStation 3 Control Board Replacement: 步骤 8 中的图像 1,1
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
  9. PlayStation 3 Control Board Replacement: 步骤 9 中的图像 1,1
    • Remove the control board from the lower case.
结论
21等其他人完成本指南。
2指南评论
I don't have the same ps3 as in the tutorial and my control board is broken. What can i do now?
McGarvey - 回复
Could anyone tell me if they would have the connection pin of this board, as I would like to fit it into a motherboard.
Allan Fabian Santos Souza - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 57
过去 30 天: 208
总计 52,158
