跳转到主内容
PlayStation 3 CECHH01 Power Supply Disassembly
你所需要的
  1. PlayStation 3 CECHH01 Power Supply Disassembly, Remove HDD: 步骤 1 中的图像 1,3 PlayStation 3 CECHH01 Power Supply Disassembly, Remove HDD: 步骤 1 中的图像 2,3 PlayStation 3 CECHH01 Power Supply Disassembly, Remove HDD: 步骤 1 中的图像 3,3
    • Using fingernail, or spudger, remove the cover.
    • Remove PH1 screw
    • Pull HDD out.
  2. PlayStation 3 CECHH01 Power Supply Disassembly, Remove security screw: 步骤 2 中的图像 1,2 PlayStation 3 CECHH01 Power Supply Disassembly, Remove security screw: 步骤 2 中的图像 2,2
    • Remove sticker an underlying rubber tab
    • Remove the T8 security screw
    • Pull cover towards you to remove
  3. PlayStation 3 CECHH01 Power Supply Disassembly: 步骤 3 中的图像 1,2 PlayStation 3 CECHH01 Power Supply Disassembly: 步骤 3 中的图像 2,2
    • Remove the 6 long medium screws
    • Remove the medium medium screw. This screw is conveniently marked with an S if you forget what goes where.
    • The blueray drive is NOT screwed down. Do not tip the console!
    • Use a finger to press the tab next to the medium length screw and lift. The case pivots on the front.
    • When putting back together, place the front edge and rotate back. The screws will pop everything back in place.
  4. PlayStation 3 CECHH01 Power Supply Disassembly, Remove Blueray drive: 步骤 4 中的图像 1,3 PlayStation 3 CECHH01 Power Supply Disassembly, Remove Blueray drive: 步骤 4 中的图像 2,3 PlayStation 3 CECHH01 Power Supply Disassembly, Remove Blueray drive: 步骤 4 中的图像 3,3
    • Flip the Blu-Ray drive over and lift the black tab to remove the ribbon cable.
    • Disconnect the 4 pin cable attached to the Blu-Ray drive.
  5. PlayStation 3 CECHH01 Power Supply Disassembly, Remove power supply screws: 步骤 5 中的图像 1,3 PlayStation 3 CECHH01 Power Supply Disassembly, Remove power supply screws: 步骤 5 中的图像 2,3 PlayStation 3 CECHH01 Power Supply Disassembly, Remove power supply screws: 步骤 5 中的图像 3,3
    • Remove M screw
    • Remove medium medium screws
    • Remove long M screws
    • When putting back together, the fine thread screws are marked with M.
  6. PlayStation 3 CECHH01 Power Supply Disassembly, Unhook power supply: 步骤 6 中的图像 1,2 PlayStation 3 CECHH01 Power Supply Disassembly, Unhook power supply: 步骤 6 中的图像 2,2
    • Push down on tab and pull straight out
    • Pull straight out
  7. PlayStation 3 CECHH01 Power Supply Disassembly, Remove power supply: 步骤 7 中的图像 1,1
    • Do not use a metal spudger! There are exposed prongs that may short and shock you. I did not know this when I did it.
    • Using something non-conductive, lift this corner up to make removal easier.
    • Pull straight up to remove the power supply.
  8. PlayStation 3 CECHH01 Power Supply Disassembly, Unscrew the board brace: 步骤 8 中的图像 1,3 PlayStation 3 CECHH01 Power Supply Disassembly, Unscrew the board brace: 步骤 8 中的图像 2,3 PlayStation 3 CECHH01 Power Supply Disassembly, Unscrew the board brace: 步骤 8 中的图像 3,3
    • Remove the short medium screws
    • Remove the ground screw
    • Remove the heatsink screws and braces
    • Lift the front to remove
    • Do this slowly. The heatsinks are not screwed down and you may damage the fins if you use too much force.
    • This is the second time I've taken this apart. That's why there is no thermal paste on the chips. They do put paste on there. Too much in my opinion.
    • When putting back together, all the screw places are marked. If the hole doesn't have a marker, don't put a screw in it.
  9. PlayStation 3 CECHH01 Power Supply Disassembly, Remove the shields: 步骤 9 中的图像 1,2 PlayStation 3 CECHH01 Power Supply Disassembly, Remove the shields: 步骤 9 中的图像 2,2
    • Unscrew the M screws and unplug the board battery. Your PS3 now does not know the date and time.
    • I messed up when I put it back together. The shield goes under the top half of the HDD cage.
    • Lift this side of the HDD cage and wiggle it. The pins can be tricky.
    • Remove the shield over the USB and WiFi controller
    • Remove the USB and WiFi controller. It lifts straight up. Remove the white tape.
    • Lift from this side to remove the motherboard shield.
    • The motherboard lifts right out
  10. PlayStation 3 CECHH01 Power Supply Disassembly: 步骤 10 中的图像 1,2 PlayStation 3 CECHH01 Power Supply Disassembly: 步骤 10 中的图像 2,2
    • Ok, I forgot to take a picture before unscrewing the bottom. There are 4 small medium screws.
    • The back plate lifts up
    • The fan and cover lifts straight up
    • The heatsinks are not screwed down and lift right out
  11. PlayStation 3 CECHH01 Power Supply Disassembly, Done: 步骤 11 中的图像 1,2 PlayStation 3 CECHH01 Power Supply Disassembly, Done: 步骤 11 中的图像 2,2
    • Insert wisdom here.
  12. PlayStation 3 CECHH01 Power Supply Disassembly, Follow steps 1-7 continue from here.: 步骤 12 中的图像 1,1
    • After completing step 7 of that guide, remove the power supply and continue from this step.
  13. PlayStation 3 CECHH01 Power Supply Disassembly, Remove 3 Bottom Screws: 步骤 13 中的图像 1,2 PlayStation 3 CECHH01 Power Supply Disassembly, Remove 3 Bottom Screws: 步骤 13 中的图像 2,2
    • Remove 3 Phillips screws from the bottom of the power supply. These hold together the upper and lower halves of the plastic power supply case.
  14. PlayStation 3 CECHH01 Power Supply Disassembly, Release 6 Latches: 步骤 14 中的图像 1,2 PlayStation 3 CECHH01 Power Supply Disassembly, Release 6 Latches: 步骤 14 中的图像 2,2
    • After removing the three screws, the power supply's plastic case is still secured by six plastic hooks and latches around the perimeter seam. It takes some doing, but if you carefully pry around the edges you can eventually release all of these without breaking any plastic.
    • Even if you do break some of the plastic latches, the case is still held together securely by the three screws that you previously removed.
  15. PlayStation 3 CECHH01 Power Supply Disassembly, Inspect the Components: 步骤 15 中的图像 1,1
    • The circuit board is now revealed in all its glory.
    • Inspect for bulging or leaking electrolytic capacitors, or obviously burned components.
    • A small tubular fuse is soldered into the circuit board near the left edge of the photo. Be sure to replace it if there is no continuity.
结论
5等其他人完成本指南。
gordonhamachi
于12/20/14注册
3,419 声望
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 36
过去 30 天: 172
总计 4,780
