简介
使用本指南来为您的PS3 更换交流电源接口
使用一个撬棒的尖端从PS3的侧面去除黑色橡胶螺丝盖。
  • 使用一个撬棒的尖端从PS3的侧面去除黑色橡胶螺丝盖。
  • 这个螺丝盖也许在保修贴纸的下面。贴纸被移除后将会改变外观并且 显示“空白”。
添加评论
从智能板上取下一个8.5毫米的T10安全Torx螺丝钉。
  • 从智能板上取下一个8.5毫米的T10安全Torx螺丝钉。
添加评论
  • 把智能板拉向硬盘驱动器,然后把它从PS3主体上抬起并且拿下来。
添加评论
  • 请注意一定要注意一下松松地放在顶盖上的小金属支架,如果你的机器配备了这样东西的话。
That small metal bracket/socket set up looks completely different in the ps3 I'm working on. Model: CECHK01.
Any suggestions?
Marcus - 回复
  • 去掉这图片中的7个螺丝
    • 6个52毫米的菲利普斯螺丝
    • 1个30毫米的菲利普斯螺丝
2 more smaller screws (don't know what size...small) just below the top middle screw and top right screw (in the picture). Look for the arrows...
E Goo - 回复
after you remove the screws, you may have to push a tab to take the cover off if you meet resistance on one side of the cover. Here is a link to a video that explains it, saved me lots of trouble:
http://youtu.be/jZgekNsRB-A?t=1m54s
ericksi33 - 回复
Thanks @ericksi33, this really helped me out.
hogurt -
1st attempt, fan loud. Ps3 lasted about 2 wks. 2nd attempt noticed very poor contact between heatsink & cpu,gpu when taking it apart. Research - Found a better way to apply thermal past. I personally disapprove of guide on this. A small bit about the size of a grain of rice in center of cpu is plenty. Clamp the heat sinks back on. Then take it apart & check contact area. Thermal paste should have spread to about the size of a quarter.(more is better. Less then a nickel size is poor contact) possibly weak clamps. Carefully applied pressure onto the cpu & gpu, pressing them into the heatsinks before clamping heatsink clamps on. Achieved greater then quarter sized thermal past spread. Fan silent in comparison & ps3 lasted about a yr. Rarely did I ever hear the fan go to high and get loud after that. About to begin my third fix on this same ps3. One of the first 80g backwards compatible. other then those notes and that this guide was for a different model ps3 (minor differences) I liked this guide. easy to follow.
brettgomes - 回复
Although the battery is described as proprietary, it looks like it is the common CR2032 lithium coin battery that is used in calculators and some computers. I haven't had to replace mine but I suspect under the heatshrink cover is a battery holder which will allow the coin battery to be removed and replaced. Then wrap with electrical tape and reinstall.
RickP - 回复
I tried this with the heatgun and it ruined my PS3. The CPU and GPU are NOW RUINED!!! It did not work for and made things worst!!! I sent it to a place to get reballed and they said the HEATGUN had overheated my processor and killed them!!! So think twice about doing this. Just because it is already broken, DON'T THINK YOU CAN'T MAKE IT WORST!
georgehollyoh - 回复
Why would you try it with a heat gun, no were is it mentioned to do that
Phillip Pereira -
There are 2 additional screws to remove , front center and front left , just behind the already marked screws.
mikentc90 - 回复
  • 从后边缘抬起前盖并且把它旋转到PS3的前部。
  • 拆掉顶盖
Disconnect the memory card ribbon cable.
Tobias Stockmann - 回复
The top would hardly budge on the left back corner and was stuck on the right back corner. There is a plastic hook that needs to be unfastened to lift the top off. It is located in a hole on the top back corner on the right hand side, so the corner straight across the on off button. Just gently push the plastic hook a bit front the rear of the machine with a spudger. It gives easily and the top will be free to lift off after that.
cornellg - 回复
  • 从主板断开蓝光的电缆
  • 如图,将插头垂直拉出插座
添加评论
  • 从最靠近电源的边缘抬起蓝光驱动器,并且把它从机箱旋转到足够接近带状电缆。
添加评论
  • 用你的指甲在蓝光带状电缆插座上翻转固定襟翼。
  • 确保翘起襟翼而不是插座本身。
  • 把带状电缆从插座上拔出。
  • 从PS3上取下蓝光光驱。
  • 如果更换新的蓝光驱动器,请将电源移到您新的驱动器上。
Not all systems look like this, some have tape instead of the flap.
gatewaynomad - 回复
Every system that I have seen has had the ZIF connector, while some had tape over the connection as well. If your connectors are taped, be sure to remove the tape, then proceed with undoing the ZIF connector.
Brett Hartt -
The version 2 systems baseboard PCB started switching to the new narrow 24 pin ZIF header/ribbon and Blu-Ray drive connection.
You should not attempt to detach the taped ribbon cable from the drive end first as described above for the older wide 60 pin ribbons. You must remove the drive and ribbon as one unit to protect the fragile ZIF sockets.
The slimmer fragile ribbon is taped to the drive housing to afford a more secure ZIF connection. The opposite base connection is slightly under the PSU.
continued
shadetree - 回复
From continued
One should firstly remove the PSU: Disconnect the drive power cable as described above. Unscrew the 5 (3-P1 2-P2) PSU mounting screws. Now leaving the power cables attached, lift the PSU off the power baseboard PCB pins and move over slightly to access the baseboard drive cable end ZIF. Release the ZIF latch and slide the entire (drive and ribbon) strait away from the baseboard ZIF to disconnect.
After the complete drive/ribbon removal, you can carefully remove the restraining tape on the bottom of the drive to release the ribbon ZIF, then remove the 24 pin ribbon from the drive logic PCB.
Install in reverse order making sure to add new tape to secure the ribbon to the drive.
shadetree - 回复
I needed to remove the PSO completely to reach the baseboard drive cable end ZIF. To do that disconnect the power and data (I assume) cables and then pull the unit straight up. To longish prongs are heading straight up into it from the baseboard and it is a bit tight, so gently pull until it's clear.
cornellg -
If you are replacing the Blu-ray drive, you must use the same daughterboard that came with your PlayStation 3. The daughterboard is paired to the motherboard, and the Blu-ray drive will not work with a different board. -------------- I understand however my daughterboard is not on the bottom of the blu-ray drive it must be on the inside. Is there any advice out there on how I go about doing this as I am not sure what I am doing???? If someone could post a link or any tips it would be greatly appreciated.
jimmy - 回复
When I received my new drive there was a sheet that said you could keep the old boards but you have to 'flash' them with the ps3's digital information. Currently trying to figure out how.....
Cheffy -
  • 将控制板上的带状电缆直接从主板上的插座中拔出。
Some PS3 versions do not have a separate control board, since the buttons and LEDS are located on the motherboard (for example, in my PS3 model CECHG04). In this case steps 10, 11 and 13 are not applicable.
markp - 回复
  • 拆掉两个12毫米的Phillips螺丝,把控制板固定到底部外壳。
  • 从PS3上拆掉控制板以及它的附属电缆。
添加评论
  • 拆掉图中8个螺丝把主板组件固定到较低外壳上。
    • 7个12毫米菲利普斯螺丝
    • 1个30毫米的菲利普斯螺丝
On my machine (fat PS3 with no card reader and 2 USB ports), there is no upper right screw to remove.
alansliu - 回复
That 30mm screw is the one lower down under the power cable, not the higher up one with the embossed arrow pointing at it.
James Beegle - 回复
  • 拆下主板支架。
添加评论
  • 用撬棍的平底撬起硬盘驱动器支架使其远离低的一端。
  • 拆下硬盘盖。
添加评论
  • 从底板上抬起主板组件。
My Ps3 was a little different..
The rear backing plate is connected to the fan shroud beneath the unit that is screwed into the bottom of the case.. And these large chrome pieces attatched to the fan were stuck to the tray that the board is on. Came a part pretty rough, guessing the ps3 got so hot it turned the grease into glue lol
intotec239 - 回复
If you already suspect you may have a slightly different PS3 model to the one pictured here STOP RIGHT NOW! Do not try and lift the motherboard off the lower casing if it is not coming easily. On mine, the cooling fan and heat sinks have extra screws directly into the lower plastic case and you will not be able to lift the motherboard out until after you have done Step 27. So skip this step, continue through the guide, skip 18-23 (you probably don't have a memory card reader). After unscrewing the 4 screws in Step 27, pull hard to separate the motherboard from the heat sinks (they will be attached with thermal paste like a glue). Only then will you be able to access the screws to separate the large fan and heat sinks from the plastic lower case.
Incidentally I totally smashed mine trying to get the lower case off here at step 15 - I broke the screws off, warped the metal on the heat sink and snapped pieces of plastic. But I continued and did the heat gun stuff and it still actually worked!!
Fat Albert - 回复
  • 移除将接地皮带固定在底壳上的7.7mm十字螺丝。
On my PS3 the ground wire(green/yellow) was actually routed under the bolt for the power supply, so I had to remove the power supply before I could removed the AC inlet
jorgebustos2254 - 回复
  • 将交流电源电缆稍微拉离后盖,以创造间隙来找到交流电源连接头。
  • 在按下其锁定机构的同时,将交流电源连接头拔出电源插座。
添加评论
  • 从后盖的底部拉出交流电源插座,查看可能被卡住的任何电缆。
I had to loosen the two screws on the perforated cover to get the ground wire out.
asciimo - 回复
Had to remove 2 screws (the top 2 screws marked in step 25) to get the ground cable out.
deuxphoria - 回复
Like @asciimo and @deuxphoria, I had to loosen the same two screws to get the ground wire out. When you're putting the PS3 back together and you're doing the steps in reverse, it helps to leave those two screws unscrewed during Step 25 and wait until you put the AC inlet back in Step 18.
hogurt - 回复
You can put the 2 screws back in step 25, just put the AC Outlet before you put in the back plate. (Do Step 18 before step 19 when you are going in reverse)
xaviertaylor - 回复
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
18等其他人完成本指南。
特别感谢这些译者︰
100%
Leon赵国鑫正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 13
过去的30天: 78
总计 28,827
