跳转到主内容
PlayStation 2 Top Cover Replacement
你所需要的
  1. PlayStation 2 Top Cover Replacement, Top Cover: 步骤 1 中的图像 1,3 PlayStation 2 Top Cover Replacement, Top Cover: 步骤 1 中的图像 2,3 PlayStation 2 Top Cover Replacement, Top Cover: 步骤 1 中的图像 3,3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
  2. PlayStation 2 Top Cover Replacement: 步骤 2 中的图像 1,1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. PlayStation 2 Top Cover Replacement: 步骤 3 中的图像 1,1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Top Cover Replacement: 步骤 4 中的图像 1,2 PlayStation 2 Top Cover Replacement: 步骤 4 中的图像 2,2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
结论
29等其他人完成本指南。
jwyoung
于11/04/09注册
2,596 声望
创作了5篇指南
团队
Cal Poly, Team 19-1, Maness Fall 2009 Cal Poly, Team 19-1, Maness Fall 2009 的会员
CPSU-MANESS-F09S19G1
4 名成员
创作了34篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 39
过去 30 天: 171
总计 16,384
