简介
This guide will walk you through step-by-step on how to properly remove and install the motherboard in the PlayStation 2 Slimline.
配件
没有特定配件。
Turn off the PlayStation 2 (or PS2) and carefully unplug from the power source. Check to see there are no discs inside the console before flipping the game system upside-down.
Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
What you see in this picture is the electronic components found in the PS2. We are now going to remove the top metal casing found on top of the motherboard.
7等其他人完成本指南。
