本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will walk you through step-by-step on how to properly remove and install the motherboard in the PlayStation 2 Slimline.
你所需要的
步骤 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
注意:步骤 1-7 源自标记为进行中的 指南。
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
步骤 8 IR Sensor
注意:步骤 8 源自标记为进行中的 指南。
Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
What you see in this picture is the electronic components found in the PS2. We are now going to remove the top metal casing found on top of the motherboard.
12等其他人完成本指南。
