跳转到主内容
简介
This guide will walk you through step-by-step on how to properly remove and install the motherboard in the PlayStation 2 Slimline.
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  1. Locate the six feet on the bottom of the PS2.
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  2. Remove the five visible feet from the bottom of the device using a spudger. Remove the five visible feet from the bottom of the device using a spudger. Remove the five visible feet from the bottom of the device using a spudger.
    • Remove the five visible feet from the bottom of the device using a spudger.
  3. Remove the sticker and then remove the 6th foot. Remove the sticker and then remove the 6th foot.
    • Remove the sticker and then remove the 6th foot.
  4. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  5. Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides. You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins. You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
  6. If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  7. Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard. Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard. Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
    • Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
  8. Identify the clock battery, then use tweezers to disconnect the connector from the motherboard. Identify the clock battery, then use tweezers to disconnect the connector from the motherboard. Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
    • Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
  9. Gently lift the battery up from the battery compartment using a spudger. Gently lift the battery up from the battery compartment using a spudger.
    • Gently lift the battery up from the battery compartment using a spudger.
  10. Locate the fan component of the motherboard of the PS2. With your fingers or tweezers, peel off the sticker that holds down the fan's wiring. With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
    • Locate the fan component of the motherboard of the PS2.
    • With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
  11. Detach the terminal (white covering) to the red and yellow cords from the motherboard to the fan with the use of tweezers. Detach the terminal (white covering) to the red and yellow cords from the motherboard to the fan with the use of tweezers.
    • Detach the terminal (white covering) to the red and yellow cords from the motherboard to the fan with the use of tweezers.
  12. Locate and unscrew the three 1.6mm screws located next to the base of the fan. They are located off the curved edge of the fan.
    • Locate and unscrew the three 1.6mm screws located next to the base of the fan.
    • They are located off the curved edge of the fan.
    • Once you have removed the three screws, you are able to remove the fan from the PS2.
  13. Locate the optical drive on the motherboard. Locate the optical drive on the motherboard.
    • Locate the optical drive on the motherboard.
  14. Unscrew the four 4.0mm screws that mount the optical drive to the motherboard. Unscrew the four 4.0mm screws that mount the optical drive to the motherboard. Unscrew the four 4.0mm screws that mount the optical drive to the motherboard.
    • Unscrew the four 4.0mm screws that mount the optical drive to the motherboard.
  15. Locate the three ribbons that are attached to the motherboard.
    • Locate the three ribbons that are attached to the motherboard.
    • Note: These ribbons are different sizes: one large, one medium and one small sized ribbon.
  16. Using tweezers, gently detach all three ribbons from the motherboard terminal.  Unlock the middle orange ribbon to lift the black tab up on either side. IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it. IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
    • Using tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon to lift the black tab up on either side.
    • IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
  17. Gently lift the optical drive away from the motherboard. Gently lift the optical drive away from the motherboard. Gently lift the optical drive away from the motherboard.
    • Gently lift the optical drive away from the motherboard.
  18. What you see in this picture is the electronic components found in the PS2. We are now going to remove the top metal casing found on top of the motherboard.
    • What you see in this picture is the electronic components found in the PS2. We are now going to remove the top metal casing found on top of the motherboard.
  19. Locate the one 2.4mm screw that mounts the metal casing to the top of the motherboard and unscrew the screw with a Philips Screwdriver.
    • Locate the one 2.4mm screw that mounts the metal casing to the top of the motherboard and unscrew the screw with a Philips Screwdriver.
  20. Gently lift the metal casing from the motherboard. Then lift the motherboard from the plastic outer shell.
    • Gently lift the metal casing from the motherboard.
    • Then lift the motherboard from the plastic outer shell.
    • You should have three separate components: The metal casing, the motherboard and the top half of the outer shell of the PS2.
  21. Flip the motherboard over. Locate and unscrew all five 1.6mm screws that mount the metal plate to the motherboard.
    • Flip the motherboard over.
    • Locate and unscrew all five 1.6mm screws that mount the metal plate to the motherboard.
    • Note that there are four on one side and one on the other.
  22. Gently lift the metal plates from the top and the bottom of the motherboard. Gently lift the metal plates from the top and the bottom of the motherboard.
    • Gently lift the metal plates from the top and the bottom of the motherboard.
  23. Remove the plastic film that is sandwiched in between the metal plate and the motherboard.
    • Remove the plastic film that is sandwiched in between the metal plate and the motherboard.
  24. After you have detached all the other components, it should look like the image shown. After you have detached all the other components, it should look like the image shown.
    • After you have detached all the other components, it should look like the image shown.
结论
8等其他人完成本指南。
Jared Hirata
于2013年04月09日注册
621 信誉积分
创作了7篇指南
团队
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G4
3 名成员
创作了21篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 26
总计 5,981
