跳转到主内容
简介
This guide will walk you through step-by-step on how to properly remove and install the IR sensor in the PlayStation 2 Slimline.
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  1. Locate the six feet on the bottom of the PS2.
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  2. Remove the five visible feet from the bottom of the device using a spudger. Remove the five visible feet from the bottom of the device using a spudger. Remove the five visible feet from the bottom of the device using a spudger.
    • Remove the five visible feet from the bottom of the device using a spudger.
  3. Remove the sticker and then remove the 6th foot. Remove the sticker and then remove the 6th foot.
    • Remove the sticker and then remove the 6th foot.
  4. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2. After all of the feet have been removed,  Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  5. Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides. You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins. You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
  6. If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  7. Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard. Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard. Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
    • Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
结论
另外一个人完成了本指南。
Jared Hirata
于2013年04月09日注册
621 信誉积分
创作了7篇指南
团队
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013 的会员
CPSU-REGAN-S13S17G4
3 名成员
创作了21篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 3
总计 1,581
