简介
This guide will walk you through step-by-step on how to properly remove and install the IR sensor in the PlayStation 2 Slimline.
你所需要的
步骤 1 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
注意:步骤 1-7 源自标记为进行中的 指南。
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
4等其他人完成本指南。
